Yep, first road trip with GDE tune installedDid you mean to post in this thread?
Ahhh, ok. How was your def usage?Yep, first road trip with GDE tune installed
What was your mpg before?Yep, first road trip with GDE tune installed
Usually 25-26 highway once I did the lift and tires/wheels.What was your mpg before?
My wholesale dealer is still telling me no eta. It took me 3 months just to get a pair of new blind spot sensors. Things are ridiculous right now.Any updates on ecm availability? Still nothing from my March 22nd order
I was at GDE Tuesday morning getting the Tune reflashed. I saw about 12 PCMs there on the Shelf.
They had ordered them around 6 months ago and had just gotten them in. However at $600, I passed on getting one.
Dealers want $300 and the online OEM sellers want about $200 for one , IF they can get them.
Malodave
The GDE tune comes with a handheld device you plug into the OBD2 port to install their tunes. Once installed you use the same device to change back to stock for dealer visits and then to reload the tune. You do not need a spare PCM.Kind of a dumb question, but I appreciate if someone can answer. Im in California and my truck has to pass emissions testing. If I managed to get a GDE tune and bought an additional PCM to keep stock, can I the pass the smog inspection just by popping the stock PCM in?
Wrong. The handheld is to load the Trans tune. Gde said at least 4 years if ever for a handheld unit. You need a spare pcm to swap back if you wantThe GDE tune comes with a handheld device you plug into the OBD2 port to install their tunes. Once installed you use the same device to change back to stock for dealer visits and then to reload the tune. You do not need a spare PCM.
Thanks. Didn't know you still have to send in the PCM (was misinformed). I stand corrected.Wrong. The handheld is to load the Trans tune. Gde said at least 4 years if ever for a handheld unit. You need a spare pcm to swap back if you want
how muchI'm selling my new pcm if anyone is interested.
Would swapping back allow me to pass emissions in California?Wrong. The handheld is to load the Trans tune. Gde said at least 4 years if ever for a handheld unit. You need a spare pcm to swap back if you want
It should since GDE doesn't delete anything.Would swapping back allow me to pass emissions in California?
