When someone replies about someone they know nothing aboutyou are not a mechanic you are a desk jockey and know nothing what you talk about
What Data is Available from OBD? | OBD Solutions.
This is a direct quote of the person you replied to:you are not a mechanic you are a desk jockey and know nothing what you talk about
This is a direct quote of your response to that person’s question:Just got called for the recall on this. Dealer Service Department stated that it's a quick computer flash. Is this going to affect the AlfaOBD changes I've made. IE Tailgate Ajar and Bedlights?
Thanks,
DusterJoe
Your answer to that person’s question is not correct at all. The act of the dealer simply plugging a reader into the OBD2 port can not possibly affect any changes that were made with AlfaOBD. In order for that to happen, they would have to purposely perform the restore vehicle configuration function.as long as the dealer does not put a reader in the obd-2 port.
Just because a tech plugs into the OBD port doesn't mean everything is wiped out. For example, my wife has a Wrangler, that I installed 34" tires on ans set tire size with Alfa. I can plug into the car, program multiple models and still have the setting I set with Alfa. If I initialize the ABS or perform a vehicle reconfiguration while using Witech, the programed tire size will be reverted back to stock. Those are really the only 2 things will mess up what you have done w/ Alfa.you are not a mechanic you are a desk jockey and know nothing what you talk about
Seems you were the one proven wrong. Might want to check yourself before commenting further.that is what you do
at least you admit it
no one has proven me wrongSeems you were the one proven wrong. Might want to check yourself before commenting further.
I didn't attack anyone, you are the one doing that. I just said the dealer plugging in the OBD2 reader has nothing to do with them flashing the BCM and reverting it back to stock. Which is doesn't. JIMMY07 set you straight, or are you going to argue with him as well?no one has proven me wrong
unlike you who is only a Integrated systems lead technican.
Can't prove anything I said was factually wrong, just different than your opinion, so let's attack the person, not his advice.
Screen shot of your comment and the post you were replying to. Based on the comment you were replying toz your comment insinuates that the dealer plugging in the OBD 2 reader will change settings. If that's not what you meant then my reply was spot on, and your comment doesn't make any differenceAGAIN NO ONE SET ME STRAIGHT
again read what I posted!!!!
I know what I saidScreen shot of your comment and the post you were replying to. Based on the comment you were replying toz your comment insinuates that the dealer plugging in the OBD 2 reader will change settings. If that's not what you meant then my reply was spot on, and your comment doesn't make any difference View attachment 169709
It can't tell what was changed, unless they were trying to compare it to factory configuration. And still doesn't matter in regards to the recall. So what was the point of your comment?and putting a reader in the port ONLY READS WHAT WAS done
why is it so hard for a Integrated Systems Lead Technician to understand it is ONLY reading something NOT modifying anything
Bro take a breath. Take a step back, eat an edible and look at what you typed and why people are replying in the way they did/are. Then you add in some link to obd port like that was some kind of new info. Unless you have a factual answer to the question that was asked, why even post what you did?NO ONE SAID IT IS WIPED OUT
I only said "as long as the dealer does not put a reader in the obd-2 port."
STOP PUTTING WORDS WHERE THERE ARE NOT ANY!
My radio software is an older version so I'm trying to use the OTA update and avoid a trip to the dealer. I go to the vehicle setting and pick software update, the truck connects to my wifi but then nothing happens. No "update now", no "check for updates" or any similar phrase. What do I need to do to kick off an update?
The notification letter says "your vehicle's radio software can be reprogrammed remotely using firmware over the air technology in the near future". Does that mean it's not ready yet?
Try leaving the truck on until the update finishesHas this hit over the air yet? My radio has been trying to update for a week now. The radio stays on when I turn the truck off get out and lock the door. I will get in the truck the next day and the radio says failed to update error code -4. Just trying to figure out if this is the latest update or not.
My radio is showing Build Number: FCA-MY23.T25.48-PROD
