PLANMAN5740
YEP THEY FOUND THAT OUT!Filler neck is not going to solve this issue.
Mines treating it like a surprise, yet 3 trucks are there for the same thing. My 2021, been there 9 days. My neighbor 2018 was out of warranty, they sold him a new tank, now his new tank won't take gas. Florida Lemon Law says less than 24 months from delivery, 3 failed fixes and 15 days, you can claim it a Lemon and be reimbursed cost of the vehicle, expenses and atty fees.I've got a 2020 Ram and had the problem very infrequently and now have it every time I go to fill up. I can maybe get 3-4 gallons before it begins to backup. I've tried all solutions listed here; pull the nozzle out and turn the nozzle head. None seem to work now. I'll be making my dealer visit before my 3 yr warranty runs out. I'd be curious to know how receptive the Dealerships are to the issue. Anybody have any feedback??
Where is that line located?one had good result blowing with compress air the small vent line, have you try that, maybe its just that that got dirty
its attach to the filler tube/ neck about 2 inch from the top the the tank, near the tank i beleive a rubber hose make the connection from the line to the tankWhere is that line located?
Gotcha. So if it’s plugged, while pumping gas the air can’t escape from the tank.heres a picture, its the small tube in this picture, the.filler tube assembly you have might be different from this picture but should still have the small vent tubeView attachment 149218View attachment 149219
i guess so, i never try it because i dont have this problem, but in this very same thread, one member had it done and said it fix the problem, so i figure since its easy to do, that those who have this problem could try thatGotcha. So if it’s plugged, while pumping gas the air can’t escape from the tank.
My son had this done at the dealership under warranty and it solved his issue so far after several fill-ups. (post #203)Gotcha. So if it’s plugged, while pumping gas the air can’t escape from the tank.
got me thinking of something, this is pure speculation but, are the pump nozzle all the same lengh( the part that actually go inside the filler neck) ? if not what if that vent line is desing connecting a little to low on the filler neck and that some pump nozzle do not get pass that vent line connection to the neck then gas would enter the vent line as well, so without vent the gas dosent go down fast the filler neck to the tank and stops.the pump nozzle.. next time i go out i will try to see if i can see were the vent meets the filler neckGotcha. So if it’s plugged, while pumping gas the air can’t escape from the tank.
Hey there,Has anyone brought this up with @RamCares ? I've got a '20 Limited eTorque with the 33 gallon tank and have started having this issue over the last couple months. Been driving me crazy!! I'm fresh out of warranty so I'm not looking forward to having to pay for them to fix something that, based on what I've read here, wasn't properly designed to begin with. Hopefully we'll catch a break...
Hey there,I have a 2020 Ram 1500 Big Horn etorq. 5.7 3.92 gears. Love the truck but after 50k it started not taking gas. I tried different pumps some a little better but takes so long many stops. Took it to my dealer they cleaned a filter $250 later worked good for about 1.5 months now back to not taking gas. I really don't want to spend $250 every other month to fix this issue starting to get disappointed with this truck. I guess I will try dealer again. Any feedback would be great. Thank you
Hey there,
If you'd like some assistance with this, we'd love to see how we can help. Would you mind sending us a DM with more information if you're interested?
Callie
Ram Cares
good jobBeen having the gas filling problem again lately after getting a new tank and filler tube a year ago. After the new tank and filler tube, the problem went away for nearly a year, then came back recently. Scheduled an appointment at the local dealer.
On the morning that I was headed to the dealer, they called me and cancelled my appointment because they are too busy and don't have enough techs. Very strange.
So, on my own and without help from the dealership, I tested a theory. It seems like gasoline vapor and liquid are forming a trap, or vapor lock, in the filler tube. So, I stuck a rod down into the filler tube and the rod came back completely soaked. At the time, the tank was only about 1/4 full. The fill tube should have been pretty dry. This rod might have cleared the vapor lock. The second thing I did was go looking for a gas pump where the ground is at an incline going down away from the gas pump. This is really difficult in SE Texas. It is really flat here. Anyway, I did find a few gas stations where the pumps on the ends are on inclined ground/concrete. I'm thinking if the filler tube is at more of an incline, then maybe this helps clear the trap or vapor lock. So far, this has worked great. I have filled up three times with no problems.
Talked to my son today, the fuel tank filling issues returned. He's taking it back in Friday.He has only filled twice, hasn't had problems filling it since the repair. If I remember I'll give an update after several months.
Hey there,I have the 33 in my 2022 and have issues both ways. Most times its hard to get it to keep filling and have to reposition slightly the filler, but ive twice had it not shut off and make a mess.
Youd think filling up a new truck would be easy.
