Shifts And Grins Fab
Ok. Here is the products we mentioned last night. Announcement went out on IG and Facebook this morning.
The new products are as follows with links:
1) New reverse light kit for those not running our TRX tow hook brackets.
www.shiftsandgrinsfabrication.com
2) fog pocket lights
3) Front Bumper SS5 CrossLink light bar kit.
4) SS5 Front Bumper pod mounts.
5) Sequential Headlights plug and play
6) Ditch Light Kit
7) Stealth Light bar kit. Similar to our 30” light bar kit but different brackets and an 18” light bar.
Stage Series Reverse Light Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
Kits now shipping. Contact for current stock.FeaturesMount two SSC1, SSC2, or C1R pods underneath the 2019-2023 Ram 1500 rear bumper.Provides high-power reverse light, red accent light, and 4th brake light (w/ C1R option).Connects to trailer hitch wiring for simple, everyday operation of...
Stage Series Fog Pocket Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
PREORDERS START SHIPPING JULY 2023FeaturesBolt-on fitment for 2019-2023 Ram 1500.Adds brighter SAE-compliant fog lights.Plug-and-play, no modification needed.Backlight feature provides amber accent light.Highly durable powdercoated stainless steel bracket.Engineered and assembled in...
SS5 Grille CrossLink Lightbar Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
FeaturesBolt-on fitment on 2019-2023 Ram 1500.Allows you to mount a four-pod CrossLink lightbar across the grille.Ultra-high intensity, with custom-engineered TIR optics.Selectable backlight color, with eight color options.Torture-tested, heavy-duty construction.Utilizes existing mounting points...
SS5 Bumper LED Pod Light Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
PREORDERS START SHIPPING JULY 2023FeaturesBolt-on fitment on 2019-2023 Ram 1500Ultra-high intensity, with custom-engineered TIR opticsSelectable backlight color, with eight color optionsTorture-tested, heavy-duty constructionAssembled in USAOverviewPerfect Fitment. The Bumper LED Pod Light Kit...
2019-2023 Ram 1500 Sequential LED Projector Headlights (pair) | Shifts and Grins Fabrication LLC
OverviewYour 2019-2023 Ram 1500 deserves an upgrade, and Sequential LED Headlights from Form Lighting are the perfect way to do it. With these premium OE-grade replacements, you’ll add triple bi-LED projectors, sequential turn signals, startup sequence, LED running light, and a more aggressive...
6) Ditch Light Kit
Stage Series Backlit Ditch Light Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
PREORDERS START SHIPPING JULY 2023FeaturesBolt-on fitment on 2019-2023 Ram 1500.Allows you to mount two Stage Series LED Pods above the hood near the A-Pillars.Utilizes existing mounting points for easy installation.Thick-gauge stainless steel construction.Low-profile design.Assembled in...
Stealth Bumper Lightbar Kit for 2019-2023 Ram 1500 | Shifts and Grins Fabrication LLC
PREORDERS START SHIPPING JULY 2023FeaturesDirect fitment on 2019-2023 Ram 1500.Allows you to mount one 18" light bar in the lower bumper opening.CAD-designed for perfect fitment and OEM-like appearance.Utilizes existing mounting points for easy installation.Highly durable powdercoated steel...
