Need to purchase lifetime warranty
Thanks, what does this warranty cover? I spoke briefly with my dealership, I asked about the extended warranty as it relates to the rear window issue. He called me back after he spoke with his service manager and said it would not cover the rear windows leaking issue and he ( service manage) could not locate any information on any leaking rear windows and they have never had any customer report this issue. It goes without saying I'm confused.
This has been my experience...I think they are wrong, it should be covered, but there is no higher power to force the issue (short of lawyering)
whats some other numbers you guys got . Mileage you are currently at, quotes or deal you closed on as far as deductibles and what not..im sittin at 34,500, need to start thinkng of gettint one by spring
You can put in whatever mileage on the zeigler quote site and get the price. It might go up after 36k so be sure to check it out before then.
Sent from my Moto Z (2) using Tapatalk
After you reach 3 years 36K miles the warranty starts from the day you purchase it instead of backdating to the day the truck was bought. It is the same warranty but is generally more expensive than if you buy prior to the basic warranty expiring (no gaps in coverage).
The longer the policy the larger the price difference. Just taking a quick peek at Zieigler's site and the 6 year / 80K miles / $200 deductible plan is about $400 cheaper than if you waited until 36,001 miles and bought a 3 year / 36K miles / $200 deductible plan.
Keep in mind that there is an additional cost "penalty" after 12K miles and 24K miles for waiting to purchase (you are already at 34K+ miles) so that adds to the price too and may be about the same or more than if you waited to purchase after the basic warranty is up. The longer the policy you want the larger the price gap between pre- and post-basic warranty.
You don't have to buy from them but I recommend you go to Zeigler's site (https://www.chryslerfactoryplans.com/) and put in your details and run a quote for 35K miles and a quote for 37K miles and see what the price difference is to make sure you are getting the better deal for your situation.
Just remember to add 3 years (and the appropriate miles you've driven per year) to the policy for the 35K mile quote as it backdates to the day the truck was bought whereas the 37K quote will start the day you would purchase it.
I might regret it due to later tech issues but with 11k on the 2019 and zero issues I’m rolling the die. Every vehicle is different, so comparing mine to some other Ltd is fairly pointless. Same with comparing the RAM to my current Ford suv, which never needed anything from the $1700 extended warranty.
If I had any problems in the first 6-7K I’d have been much more likely to have bought a factory extended warranty.
With our low usage, we run out of time wayyy before we run out of miles.
All warranties are a gamble. You are betting that there will be problems past the 3/36 that are covered and they are betting that there won’t be. Guess who usually wins out?
I called Zeigler today and asked about their maximum plan and if it would cover the leaking glass problem and I was directed to a section on their site that said its not covered . Its still a sound plan. FYI
What’s Not Covered Under Maximum Care Plans​
Virtually the only parts and labor not covered:
  • Maintenance services and items used in such services
  • Wear items (such as tires, manual clutch assembly, brake pads, shoes, rotors, drums, belts, exhaust, and wipers)
  • Snow plows, winches and trailer hitches
  • Body and paint items, including soft trim
  • Glass and plastic lenses
  • Catalytic Converter, Particulate Filter, and Exhaust
  • Like
Reactions: cj7
Thx for checking this - guess the “body and paint items including soft trim” is a big category of excluded stufff.
I’m having a hard time deciding. This seems like a reasonable quote:
maxCare 7/85k, $200 deduct, 11k on a 20 Laramie 4WD, $1215 Ziegler.
my issue is, I never buy warranties, after my last experience ($2500 warranty on an RS6, and all I got out of that was $1300 covered).
as mentioned, the house usually wins...
whats tempting me is the somewhat sordid reputation and potential for higher mileage issues...
thoughts?
THE PLAN WILL NOT COVER, OR APPLY TO LOSS OR EXPENSE RESULTING FROM: • Repairs or replacement of any component covered by any of the Vehicle manufacturer warranties, Certified Warranty, part manufacturer warranties or recall policies; roadside assistance, loaner vehicles or other services which are eligible to be covered by the Vehicle’s manufacturer warranty or marketing programs; • Repairs required as a result of other than a manufacturing defect (such as a design defect or normal wear); • Repair or replacement of any covered component when it has been determined that the condition existed prior to purchasing the Plan; • Plan benefits where the Vehicle odometer reading has been stopped or altered and/or the Vehicle’s actual mileage cannot be readily determined; • Brake pads, shoes, rotors and drums are not covered at any time (regardless of cause of failure); • Reimbursement of services/benefits that exceed the total number of services/allowance included in Plan Coverage; • Battery and cables; any battery for a component; spark plugs and wires; lights (bulb, sealed beams, lenses); suspension alignment; wheel balancing; wiper blades; catalytic converter, particulate filter and any other exhaust system components; heat shields and exhaust hangers; throttle body cleaning; evaporator deodorizing; carbon cleaning; • High voltage battery is not covered at any time (regardless of cause of failure); • Repairs due to any alterations or modifications to the Vehicle not approved or recommended by the manufacturer, including but not limited to: (a) failure of any custom or add-on / aftermarket part (unless listed as a specific covered part); (b) emissions and/or exhaust systems modifications; engine modifications, transmission modifications, and/or drive axle modifications, which includes any performance modifications; (c) oversized/undersized tires; (d) all frame or suspension modifications; • Repairs to covered components that are the direct result of the failure of alterations or modifications not recommended by the manufacturer;
• Lift kits that exceed two (2) inches; repairs to covered components that are the direct result of the failure of a lift kit that exceeds two (2) inches; • Plan benefits necessary as a result of (a) failure to properly care for or maintain the Vehicle; (b) fire, accident, abuse, vandalism, negligence, Acts of Terrorism or Act of God including but not limited to the Vehicle rendered inoperable due to snow, ice or flood; (c) failure to properly operate the Vehicle; (d) Vehicles that have been used or are being used for competitive speed events such as races or acceleration trials; (e) pulling a trailer that exceeds the rated capacity of the Vehicle or failure to adhere to the requirements for vehicles used to pull a trailer as outlined in the owner manual supplied by the manufacturer; (f) tampering with the emission system or with any parts that could affect that system; (g) use of dirty fluids, or fuels, refrigerants or other fluids which are not recommended by the manufacturer; (h) failure due to fluid contamination or sludge; (i) modifications not approved or recommended by the manufacturer; (j) overloading rated payload capacity of the Vehicle; (k) damage incurred by off-road usage; • Fasteners, bolts and attaching hardware that does not attach a covered component to another covered component; • Repairs to a covered component where the component has been restricted by the manufacturer; repairs that are the direct result of the failure of a component that has been restricted by the manufacturer; • Repairs caused by pre-ignition detonation, pinging, improper/contaminated fuel including fuels containing more than 10% ethanol (if the engine was not manufactured for this mixture); • Plan service obtained from other than a Dealer unless authorization is first received from us. FCA US Vehicles must return to a FCA US LLC Dealer for Plan covered repairs; (Dealers cannot authorize repairs.) • Repairs required as a result of use of other than the Vehicle manufacturer’s parts during the term of the Plan, unless authorized by us; • Repairs to a covered component caused by the failure of a non-covered component and/or an aftermarket installation not performed by a Dealer, or any outside installation of "salvage or junk" components in conjunction with an insurance or damage claim. All part installations to satisfy such claims must be with new or factory authorized remanufactured components and parts; • Bodily injury or property damage arising or allegedly arising out of a defect in the design, manufacture, materials or workmanship of a covered component; • Any fines, fees or taxes which are associated with impound towing as a result of actual or alleged violation of any laws or regulations; • Plan benefits to Vehicles operated outside of the United States, Canada, Guam, Puerto Rico and Mexico; • Plan benefits to Vehicles registered outside of the United States, Guam and Puerto Rico; • Exterior - tires; trim; name plates; appliques; body sheet metal; glass; plastic lenses; paint; bright metal; bumpers; side-view mirrors (glass/ housing); wheel covers; steel wheels; aluminum wheels; rusted or frozen rims; weather strips; rust; water leaks; restricted drain tubes; wind noises; all outer body panels; spoilers; plastic and fiberglass body parts; vinyl tops; convertible top fabric; repairs or damage caused by environmental factors such as acid rain, tree sap, salt or ocean spray; • Interior - trim; carpet; upholstery; dash pad; door and window handles; knobs; buttons; moldings; arm rests and head liner; cargo cover; cosmetic appearance; torn/worn/soiled; • Mechanical - manual clutch assembly; clutch disc, pressure plate, clutch release bearing and pilot bearing (manual transmission); damage to flywheel as a result of a clutch failure; repairs to snow plows, winches and trailer hitches regardless of their installation; • Cost or expenses for teardown, rental, inspection or diagnosis of failures not covered by the Plan; • Shop supplies, waste disposal fees and materials; • Repairs to any Vehicle where the title has become branded or the Vehicle has become restricted by the manufacturer after the purchase of the Plan; • Maintenance services specified in the owner’s manual and the parts used in connection with such services; • Repairs to a covered component caused by the failure of a non-covered component and/or an aftermarket installation not performed by an authorized Dealer; • Repairs or replacement to components covered by the Hybrid System Limited Warranty (refer to Warranty booklet for details); • Hybrid components: hybrid charging system; hybrid electric cooling system; hybrid power invertor system; • Portable Units including but not limited to - headphones; I-Pods; GPS units; DVD players; laptop computers; cellular phones; any hand-held device; Navigation DVD; • Repair or replacement of Performance parts, Performance enhancing parts; repairs to covered components that are the direct result of failure of a performance part; • Any economic loss of any kind, including but not limited to rental car expenses, consequential damages, incidental damages, or other losses that relate in any manner to your use or loss of use of the Covered Vehicle.
Wow...so the eTorque battery isn’t covered either...
...nor is anything they determine to be a design defect....
The eTorque battery is covered for 8/80k as it is an emissions control device.
But yes, I'm sure it will be an expensive replacement after that.
Yeah. Is the leather considered “soft trim”?
Damn but thats a lot of excluded items. Easier to say what is covered...
EXACTLY what was the price Robbins offered vs Zeigler's offering?
2965 for 8 year 0 deductible.
Want to see the email from Zeigler where they literally said they won't beat him?
And I quote "Thanks for the email. Unfortunately, we cannot match that price. If you have any questions, we will be available Monday morning at 8am EST 269.685.3557"
Robbins in actuality appears to be the cheapest. Perhaps you should email Robbins -> [email protected]
Actually it is not. That's more "legal" crap than what it won't cover. It covers everything except wear and tear items for the most part.
Go to the MOPAR Warranty website and check it out. 99% of the truck is covered.
There’s always legal mumbo jumbo to protect themselves, not necessarily to deny any work on the policy.
They need an out when someone puts an 8” lift on and things start wearing out quickly, somebody jumps their TRX and nearly breaks it in half, or someone submarines their Jeep Rubicon and has electrical problems then takes it to the dealership to fix for free.
I’m not the one they are protecting themselves against. I don’t plan to go in for every little thing but if my engine takes a dump or my radio quits I’ll be there to cash in.
Just my .02
The difference was $50 between the two ($3015 vs. $2965) But its good that you were able to save $50 additional.
I have no desire to dispute the quote or contact Robbins, as I bought my ESP many months ago from Zeigler. I was just curious what your quote price was.
