Mid Travel Build
how did the bumpstops come out ? pic of how you tapered them?
I didn’t use them. However if you are going with a stock style shock they should work just fine. I don’t believe you can buy just the sumo spring. If I was you just use those energy Suspension ones. They are 1/4 of the cost
my suspension is just the bds lift kit 4 inch fox 2.5 all around
Well the back is still an issue. Way better but still likes to buck. I still have some tuning to do on the bypasses.IMG_1354.jpeg
Thinking about rocking these out back. They should be just short enough to fit under the bed
Back is working much better. Spend about 2 hours shock tuning. Going to add some hydro bumps next year sometime after I rebuild the front coil overs.
I love polished. No one runs them anymore. They're gonna look slick.
How are the front bump stops holding up? Had a couple fabricators told me the stock lower control arm wouldn’t hold up to having a bump stop strike on it
Perfectly fine. Trucks been in the air at least 50 times.
Nice! Thank you so much! I really want to add some front bumps to give me that bottom out protection. Might just see if they can plate the area just to be safe as well. Love the creativeness of the suspension so far! Followed you on tiktok
