I wouldn’t run a sway bar even if I didn’t have bumps. They can act similar but are 2 completely different things. I’m not saying to remove a sway bar to anyone. It’s just my preference as each front wheel can now act independently.
got it was tempted to remove the front just to see how it drivesI wouldn’t run a sway bar even if I didn’t have bumps. They can act similar but are 2 completely different things. I’m not saying to remove a sway bar to anyone. It’s just my preference as each front wheel can now act independently.
Yes blue. I tested the bump travel on my icons and had almost 2 inches left of travel when the axle was all the way against the cans holding the factory bump stops. The icons are the same length as my factory rebel shocks. The first thing that will contact is the upper arm with the fame at about 3/4 of an inch after the stock bump stop cups are cut off. The blue springs compress about 70-80% of there original size I have about an inch before that point.You say blue? I like the clean install, I used the sumo clamps on the OEM cups. I am seriously wondering how safe to truck parts the blue sumos compare to OEM bumps at full compression, if they are safe or if the OEM are really junk, or what... I am riding on the blue at ride height with the sumo spacer and cup clamps - very rough ride, need to do something, probably pull the spacer and maybe taper the sumo if you think they are as good as the OEM at protecting bottom outs.
Wichita Kansas area.Where are you located? We have raptor runs here as well.
do you have part number?Yes blue. I tested the bump travel on my icons and had almost 2 inches left of travel when the axle was all the way against the cans holding the factory bump stops. The icons are the same length as my factory rebel shocks. The first thing that will contact is the upper arm with the fame at about 3/4 of an inch after the stock bump stop cups are cut off. The blue springs compress about 70-80% of there original size I have about an inch before that point.
any reason you went with that kit and not the one thats for ram ?
Well one I got it for $100 and 2 the ram kit is trash. You make things worse with that kit. You have to understand suspension to get it but basically you greatly limit travel with the ram kit. The way I did it you get the best of both worlds. My goal was to gain more uptravel and it really works well.any reason you went with that kit and not the one thats for ram ?
just wanted to know. hHa i will go with what you are saying just was looking at it and wondering …. also have a link to the ones you grabbed ?Well one I got it for $100 and 2 the ram kit is trash. You make things worse with that kit. You have to understand suspension to get it but basically you greatly limit travel with the ram kit. The way I did it you get the best of both worlds. My goal was to gain more uptravel and it really works well.
Part number ssr-117-40. However you only really need the spring itself. Might be able to save $100 just ordering the springs.just wanted to know. hHa i will go with what you are saying just was looking at it and wondering …. also have a link to the ones you grabbed ?
