Limited with Active Air Dam...
Hihosilver
Hi everyone, new here been enjoying my truck for about a month now.
Figured out most of the gadgets and getting used to all the updates over the past 3 Dodge/Rams I have had over the years.
Been reading that the Limited with air ride suspension does not have the active air dam. Well mine has it and it does activate as it should.
When the truck goes to aero mode it tucks back in before the suspension starts dropping.
If in normal mode then it does retract right about 40mph as it should.
Not sure if this has been discussed but everything I have been able to find on the interwebs points to not having the active airdam system if it has air ride???
Dave
duke2001
Dave
Curious as to how you know this? Are there lights or dash displays? And everything thing I have read says if you have a Limited you have aero only!
Hihosilver
Had the wife drive it while I rode next to the truck on my motorcycle. Can clearly see it drop the air dam right around 40mph and at 65 or so it goes up before the suspension drops into aero mode
JJRamTX
Colorado and Texas.
Well this is a very curious thing. Makes me want to see the hardware underneath to see if it is installed. You may have a Unicorn!
Rick J
Northwest Washington
ACTIVE AIR DAM
As the Ram 1500 approaches 30 miles per hour, a Class-Exclusive active air dam automatically extends downward 2.5 inches to help reduce drag and make towing more efficient. This feature is standard on all Ram 1500 models that are not equipped with the available air suspension.
I know for sure that my Limited doesn't have an active air dam. The OP may have 1 of 1. Could be valuable :p
Neurobit
RAM Sorcerer
Texas
Dave
I think you’re mistaking the air dam with Aero mode. Two different things.
The air dam protrudes from the bottom lip beneath the bumper and it’s speed dependent, and only available on trucks without air suspension.
Since air suspension trucks lower themselves automatically in Aero mode, the air dam is not necessary as it would be redundant.
What your truck does have, in addition to aero model is the active shutter grill, which open and close depending on speed.
Cheers,
Hihosilver
What I read should be that its not but then I crawled under need and it was there,. So I though maybe it's just there because of the build but not hooked up. It is and it works. My build list shows Fixed front air dams and next line says Active front air dams
Hihosilver
What your truck does have, in addition to aero model is the auto-closing louvers in the bottom portion of the grill, which open and close depending on speed.
Cheers,
30992
#5 is what is installed on my truck and it works.
Biga
Cincinnati
Interesting, could be installed by mistake or Ram is starting to put them on air suspension trucks as well. I would image clearance is pretty tight with it deployed when the truck is in Aeromode.
tdager
Pic of build list?
HaKkErO
I would like to see the build list. If OP has ORG also then I don't see a problem with clearance.
cra1g
Sherwood, OR
That's very interesting. If the air dam goes back up when the suspension goes to aero mode, then the software has to know BOTH are installed. It sounds less like a build mistake, and more like something they're configuring intentionally now.
What's your build date?
Hihosilver
This is indeed interesting ... pics or it didn't happen? :D
-John
I will crawl underneath and take pics, as far as pics while its working, not going to happen since I am on my bike and in Illinois its on your record now if you touch a phone while driving/riding
