2020blckout
Are this 10 ply??I put 33" x 12.5R22 Nitto Terra Grappler G2's on my 2019 Limited with Air Suspension and have zero rubbing issues with no lift or leveling. See picture in my avatar.
How do they ride on highway compared to the factory touring tires.Here you go...
Again, these are 33x12.5R22 Nitto Terra Grappler's. I had the OEM wheels powder coated in "ink" colored polished black.
I have plans to add 2 inch spacers and a 2 inch leveling kit.
View attachment 38855View attachment 38854View attachment 38843View attachment 38845View attachment 38847View attachment 38850View attachment 38851View attachment 38852View attachment 38853
Sorry to join the party late...
I am running the Nitto 305/50/22 ... they stand just a little over 34 inches tall. As long as I have my air suspension set at "normal" height or higher I do not have any rubbing issues. In the lower settings I had a slight rub in reverse while turning sharp (like backing into a parking space). However, I have trimmed the plastic that caused the rub and all is good in that regard. Final thing to think about... in the lowest height setting, when turning to full lock the sidewall is about 1/8 of an inch from the plastic arm that helps control the ride height. Hope all this helps.
Plenty of room for 305's. The rim width is tire company approved but it is on the narrow side of the range.May be the angle.. but it looks like the 305 is too wide for those rims. Which may help cause rubbing. Maybe a 285 or 290.
..... I can no longer make right or left turns but the truck looks AMAZING when sitting or going straight.....
Maybe spaces might help.
The Terra Grapplers are less aggressive than the Ridge Grapplers. I went with the Terra's just to get a better highway ride. They are really great on the highway, not much louder than stock and certainly more sure footed at any speed. This is my second set of Terra's (I had some on my 2009 Ram), and they wear really good. You can get 50K miles out of them!How do they ride on highway compared to the factory touring tires.
Here is some good info on the Terra Grappler:Are this 10 ply??
They are the factory running boards that came on the truckTruck looks great. What brand running boards are those? I like how low profile they are.
its just the picture... the manager at Discount Tire spent a lot of time with the truck, the tires, and me during the test fit to make sure everything would be safe for me to roll out of his shop.May be the angle.. but it looks like the 305 is too wide for those rims. Which may help cause rubbing. Maybe a 285 or 290.
That's what I think I've decided on. Any rubbing? Are they 305/45/22? How do they ride?
The Fortera's are "good" tires but you can do much better for the same cost +/-That's what I think I've decided on. Any rubbing? Are they 305/45/22? How do they ride?
They are 305 /45r22 and I haven't had a rub, yet. Improved ride from the marginally taller sidewall.That's what I think I've decided on. Any rubbing? Are they 305/45/22? How do they ride?
Not personal preference at all but based on empirical data through testing related to how well a tire handles in dry, wet and snowy conditions. Goodyear are good tires and I am not saying they aren't. However, my comment stems from the fact that there are better performing tires for our trucks that also look good.Do better? That's purely personal preference. I've owned plenty of Goodyear tires over 50+ years of driving. I haven't had any complaints. I replaced Goodyears that were wearing good and I'd gotten most of the life out of them and they were bad for winter driving. These Forteras are quiet, they are better in the snow and I like the looks.
I couldn't find a better customer rated 305 /45r22 on Tire Rack or Discount Tire when I initially started looking for an all season tire for my truck. There aren't a lot of choices.... And like I stated I've never had an issue with Goodyears. I even used Goodyear slicks on this. Had to use Hoosiers for the street.Not personal preference at all but based on empirical data through testing related to how well a tire handles in dry, wet and snowy conditions. Goodyear are good tires and I am not saying they aren't. However, my comment stems from the fact that there are better performing tires for our trucks that also look good.
What about the Sumitomo HTR Enhanced CX2? It seems to rate better than the Forterra (the Forterra is slightly better on wet/dry tractionI couldn't find a better customer rated 305 /45r22 on Tire Rack or Discount Tire when I initially started looking for an all season tire for my truck. There aren't a lot of choices.... And like I stated I've never had an issue with Goodyears. I even used Goodyear slicks on this. Had to use Hoosiers for the street. View attachment 47697
