Keyless entry keypad
YES!
No cheap, but Compustar/Drone has come up with an option. They make a “Key Locker” that allows you to keep your key fob secure in your vehicle and a keypad mounted in the front windshield. You need a Compustar remote start system. I got a quote from the local installer $800 for the PRO remote start and $200 for the Key Locker (which comes with the keypad). The salesman said it's a very popular install for Turo rentals.
Drone service is $60-120/year depending on features for app control of your vehicle.
I'll most likely be installing this on my truck when if finally arrives late this month.
tech has come a long way!
YES!
Not cheap, but Compustar/Drone has come up with an option. They make a “Key Locker” that allows you to keep your key fob secure in your vehicle and a keypad mounted in the front windshield. You need a Compustar remote start system. I got a quote from the local installer $800 for the PRO remote start and $200 for the Key Locker (which comes with the keypad). The salesman said it's a very popular install for Turo rentals.
I'll most likely be installing this on my truck when it finally arrives late this month.
That's a TON of money for a key locker...what ever floats your boat;)
I need a electronic genius to chime in and maybe shed some light on this. Ford keypads are a dime a dozen online from what I found...and they are obviously good quality.
Electronic Genius here.
There are four interacting parts in a modern car with a keypad:
1. your car's door locks (usually operated via a communication protocol called CANbus)
2. your car's favtory anti-theft computer (almost all cars have them these days)
3. The keypad of number digits you push (aka the dime a dozen ford keypad)
4. The computer that talks to all of the above, and which you set your keypad passcode into... it watches the button presses, and tells the anti-theft to shutdown and doors to unlock.
Old cars without keyfobs don't have an anti-theft device.. so you can use a very simple version of 3/4 that let you set a code right on the keypad, and which just have two wires someone hooks up to the door unlock to "push" the unlock button.... many of these cars don't even use CANbus for their door unlocks.. just direct wiring for everything.
Modern Ford keypads are "cheap" to install aftermarket because you are just installing #3.... #4 is built into the car computer that runs the main display has the software to run the keypad and to let you set the passcode into the car settings user interface.
A modern RAM truck doesn't have #4 built into the truck software, so you have to add #3 and #4 to get keypad unlock functionality that doesn't set off your factory anti-theft security. Unfortunately, there is no "standard" way to tell anti-theft to turn off, it's manufacturer specific. There might be a way to do this in the RAM factory anti-theft, or might not. If there is no way to turn it off without the keyfob, then it would need to be removed or disabled. However, in some cars this anti-theft is one system that handles both keyfob entry and ignition for the engine, so that creates another mess.
Add to this, the fact that if you want to lock the car but keep the keyfob in the car things become more complicated. Normally, if you have a keyfob sitting on the front seat, it is detected "nearby" and the doors will unlock. Ford's keyfob computer has special programming, so if you leave a keyfob in the car, but you use the keypad to lock the doors... it *disables* the keyfob unlocking, so the doors remain locked until you use the keypad to lock them again.
I have wondered if a simpler way to approach this problem is more like the way garage door keypads work. They effectively act like an additional secure opener, and when you enter the code, they send a secure rolling code signal just like a normal garage door opener does. For the car, this would mean adding #3/#4 and custom wiring them directly to a keyfob chip from the car company, so the whole thing would "look" just like another keyfob. However, the companies don't sell these keyfob chips directly, so I'd probably rip open an existing keyfob and wire directly to the buttons in it.... which could work for me, but would be a big mess to try to give to anyone else.
Any progress?
Sorry for the very late reply on this. Life got in the way, but I am back at it full time now. I have had some progress. It is more of a work around really. It will require the sacrifice of a programmed keyfob however. I will update in the next week or so on how it goes.
I don't have a solution for the keypad, but a workaround for emergency situations (lost key) could be to use the Mopar/Ram app and remotely unlock the truck? I personally keep the spare key in my center console safe (wrapped in aluminum foil), so I have a backup if I should lose my key while on a hike (or get it wet).
Not a bad idea, they sell pouches designed for that reason, I keep my keys in them to prevent signal car theft, highly recommend you keep your keys in them even when at home.
This is the one I use, you get 2 for $7, looks and works great, I use this at home and also when doing outdoor activities so I don't accidentally unlock my vehicle. Fits my oversized key, which has a decorative cover and makes it bigger than normal. Just note there are two interior pouches, the one that prevents the signal is the deeper one of course, the outer pouch won't.
cool!
