So that I actually don’t know. I don’t have a setting for that either. My blind spot setting just shows off, on lights and sound, on sound.
And I didn’t stop and look for settings when I had the trailer on. I’ll try to do that next time I hook it up. I’m curious too now.
Thanks, yes, I have the power-fold tow mirrors w/bsm lights. I think I did try that this morning or last night. The trigger is always enabling the right bsm.If I remember correctly when you and I messaged awhile back, you swapped your factory mirrors out with used OEM power fold tow mirrors w/ blind spot and door modules right? Just to rule those out, have you tried disabling the “doors blind spot mirrors present” to see if the audio portion of the BSM works without the lights in the mirrors? I doubt that is the problem based on the communication fault you’re getting, but doesn’t hurt to try that and see if you find anything different.
Are you sure the U0232 fault pops as soon as you enable the right sensor, and not the left? Double check that there is no complete circuit on the driver side tail light jumper pin 8. That sounds like the same behavior when the driver side sensor has two grounds instead of one.Thanks, yes, I have the power-fold tow mirrors w/bsm lights. I think I did try that this morning or last night. The trigger is always enabling the right bsm.
I'm going to verify the circuit is intact for each of the four wires from the terminal block under the dash back to each module's connector in the light housing and note the pinouts.
Maybe that will reveal something.
Thanks @Jimmy07 and @JBowman for your time to help me. I appreciate it.Are you sure the U0232 fault pops as soon as you enable the right sensor, and not the left? Double check that there is no complete circuit on the driver side tail light jumper pin 8. That sounds like the same behavior when the driver side sensor has two grounds instead of one.
Awesome man, glad you got it sorted. Really budget friendly approach! That’s the route I’d take if I had to do it over. Your truck is coming together nicely.Thanks @Jimmy07 and @JBowman for your time to help me. I appreciate it.
*** If I said right sensor previously, I meant left sensor. It was always the left.
I found my problem after I went back with a clear head and warm hands.
I checked the pinouts on the left-side tail light harness. There were only two sockets in the internal connector that were pushed all they way in. I guess this explains why I always had the problem when I enabled the left-side module.
I checked the right side connector and all its sockets were seated properly.
I reassembled everything and it worked!
Thanks to everyone in this thread who spent a lot of time and effort researching and compiling all this information.
Now, I have to install my new LED CHMSL and eventually find a digital mirror.
Only two sockets in there:
Pushed the rest of them in and made sure they stayed put when I connected the module.
China lights, not too bad for the savings:
Maybe this means something to the others, but I don't understand what you are saying here.im getting the same error and cannot log in to the right module also left module giving vin mismatch error, can this be cleared ?
When i go to object detection i Alfa i can connect to the left module but getting errors about vin and config mismatch i will take screen shot laterMaybe this means something to the others, but I don't understand what you are saying here.
Which same error?
What do you mean by "log in to the right module"?
What do you mean by VIN mismatch? I didn't encounter anything about VINs during my install.
You can’t do blind spot on a cab n chassis because the sensors don’t know the DD vehicle line. You also can’t change the vehicle line to a pickup without also changing the occupant restraint controller module because IT doesn’t know the D2 vehicle line.I got it to work, when I changed the vehicle line to D2 which is the 3500 pickup option,
But now I’m trying to get rid of Abs and Airbag codes
If I switch the ‘vehicle line ‘ back to DD cab and chassis airbag and Abs codes are gone but blind spot stop working also
This thread is for blind spot only. I suggest you use the search function to find threads about abs, and if you can’t find what you need, make a new thread with a lot more detail describing your issue/what you want to achieve.Also, How could I correct the Abs,
Thanks in advance, I have been looking for this information for a min
