Interior LED Lights swap out possible?
I ordered some 29mm festoons, so if you can wait a few days I will let know if they fit !
Sounds good! Appreciate that, I will wait. Please let me know and if possible post some pictures after install. Where did you order them from?
I ordered them from JDM Astar. I have always had good success with their bulbs, and I like the "color" of the white leds they use. They are usually availble through amazon, these bulbs I could not find on amazon so I ordered from them directly.
https://www.jdmastar.com/
Thank you much! I will check them out over there.
So after I did the dome light, I now have a squeak from the headliner and it sounds like the light is causing it. Anyone had this issue? Have to give the headliner a love tap to make it go away.
As promised.... 29 MM is the correct size. All went in with no issues. I changed them while I waited for my daughter to get out basketball practice this morning. As with most LED's if it doesn't light up, flip the bulb. I used JDM Astar bulbs because I used JDM Astar in all the interior bulbs I changed and I like the color of those led's.
Many thanks to you for reporting back., it looks beautiful. I ordered the same bulbs from Amazon earlier today and should receive them next week.
How did you get the cover off of the vanity lights?
Is anyone changing the floorboard lights as well?
