jamie.howlett
I ordered some 29mm festoons, so if you can wait a few days I will let know if they fit !
			Sounds good! Appreciate that, I will wait. Please let me know and if possible post some pictures after install. Where did you order them from?
Can you send the link to the bulbs?
Many thanks to you for reporting back., it looks beautiful. I ordered the same bulbs from Amazon earlier today and should receive them next week.
How did you get the cover off of the vanity lights?As promised.... 29 MM is the correct size. All went in with no issues. I changed them while I waited for my daughter to get out basketball practice this morning. As with most LED's if it doesn't light up, flip the bulb. I used JDM Astar bulbs because I used JDM Astar in all the interior bulbs I changed and I like the color of those led's.
Thanks. I can see the tabs but had no clue how to get them loose.I used a straight pick from this set https://www.amazon.com/Craftsman-Piece-Pick-Hook-9-41513/dp/B001UF7RAA
Help a brotha out heh![]()
Is anyone changing the floorboard lights as well?
These seem like a PITA to change.that's is a t10 bulb. the covers come off with you hands. i found it easier to change if you took the clip out that holds the assembly in place.
