Interior LED Lights swap out possible?
oh geez lol did u use pliers?
If you're careful, you can wrap a piece of scotch tape around the bulb as far down to the base of it you can get. Then pull it out. You may need to pull on one side, then the other, kind of rocking the bulb out of the socket. The tape should adhere strongly enough to 1) pull the bulb out and 2) keep it from falling in between the seats or somewhere else when it's removed. This is how I did it in our Explorer.
Awesome idea! I used a pliers, very very carefully, but this seems much nicer.
Sorry I can't help out with this. Limited came with LEDs. Bummer that this is not standard across all trims, just like the cargo and third brake light.
Vanity mirrors seems to be good 'ol halogen bulbs in my case though. Friggin stinks.
Wait, there's more lights to swap out to LEDs?
what size or part do I need for the back seat dome light?
Yep... Take a look at your vanity mirror lights... Your heart will sink.
Well we've got to figure this out. I still need a Ram to work on but I'm assured it's en route.
To be honest with how nice even their Bighorn trim is compared the the competition, I'm surprised they just didn't go led on all except maybe the tradesmen.
41mm
How do u guys get the new bulb in?
I had the worst time doing this mod, ended up snapping the retaining clips on the whole overhead console, thankfully the whole assembly bolts in with two 8mm bolts so it’s staying up there fine. The bulbs were damn near impossible to pull out, this is one where the juice just isn’t worth the squeeze.
Anyone know what to do with the floor board lighting?
I got my bulbs in today and figure I’d do the quick swap before I ran out to get a coffee. Wrong! The contacts where the bulb seats are very flexible and finicky and you need to line that bulb up just right.
One side popped right in but the other side just wouldn’t stick. I ended up taking the whole assembly off of the roof and held the back side of the contacts in place while pushing the bulb in with needle nose pliers so that I could make sure it seated correctly.
As mentioned, there are 2 - 8mm screws in the sunglass holder and then there are 2 tabs adjacent to each screw that have to be released. The front will then pull down. Gently slide your fingers backwards until you pop the 2 automotive clips in the rear. Unplug the plugs and you’ll have full access without being a contortionist.
Those rear clips were the ones I snapped, thankfully with the 8mm bolts it's in there pretty good and you would not know the difference.
I was scratching my head after I removed those 2 screws.....why the heck isn't this thing coming out! I told myself to just stop, grab a flashlight and take a peak and then I realized those clips. Neat in a way to see. I did ALOT of audio work to my 14 and had not seen that type of fastening used. Like you said, the 2 screws will hold it in place just fine.
Hey I was able to get the consol off no problem but my led bulbs don’t seem to fit... can you guys post what map bulbs you ordered online? Thanks
Your bulbs are correct, You need to turn the bulb 90 degrees. the metal strips on the bulb need to contact the metal on socket. It will clamp on the bulb. Keep in mind the bulbs are polar sensitive as well so if it doesn’t work flip it around and it should work
