You have a link please? and did you swap out the light in the backseat too? thanksI did mine, I bought the LEDs on amazon
Your the man! did you need 2 lights for upfront and 2 in the back? also did this give you any error codes etc? thanks!!Check this out at Amazon.com
Marsauto T10 168 194 2825 LED Light Bulbs Super Bright 5SMD Exterior License Plate Lights Lamp, Car Interior Courtesy Dome Lights Map White 2-Pack https://www.amazon.com/dp/B07C1X5HZJ/ref=cm_sw_r_other_apa_heQLBbGG66662
2 up front and the rear is a different bulb I cant remember the bulb #, I used plastic car kit toolsYour the man! did you need 2 lights for upfront and 2 in the back? also did this give you any error codes etc? thanks!!
thanks! I almost ordered 2 lol, when you get a chance can you please check your amazon order history pretty please! lol
SiriusLED Extremely Bright 400 Lumens 3020 Chipset Canbus Error Free LED Bulbs for Interior Car Lights License Plate Dome Trunk Courtesy 1.72” 41MM 42MM Festoon 211-2 569 578 6000K Xenon White https://www.amazon.com/dp/B01AHVNDZK/ref=cm_sw_r_other_apa_HbRLBbPCKSVPK
I'm waiting on a definitive answer on which bulbs for which lights and how people are accessing the front map light bulbs before I order.
So I replaced them all today and it was very easy. Just pop the plastic cover pieces off, pull the old bulbs out and plug the new ones in. Same with the back. No errors and looks a million times better. The bulbs he posted worked perfectly.
Help a brotha out hehCheck this out at Amazon.com
