You should see this . Even without a trailer attached
thanks - I will review each of the settings. Does anyone know the specific alpahobd setting that is enabling this?
Disabled all the settings and then confirmed that the settings disappeared from uconnect. Then re enabled everything with same results. Even tried unhooking the battery to make sure it’s power cycled. I have been trying other settings as well such as cabin net-Ttm trailer tow module, cabin net-Tbm, veh config 7- tsbm module present, cbc features- trailer tow present. Would you be able to confirm what is enabled on yours? I don’t want to start messing with too much and screw it all up.thanks - I will review each of the settings. Does anyone know the specific alpahobd setting that is enabling this?
the settings that are supposed to be changed are trailer selectEd, trailer type, trailer name, and integrated trailer brake module from my understanding. But no luck with those settings getting to to pop up in the cluster.
Well, that is pretty frustrating.
I know the brake controller works - I used it to pull the trailer a few weeks ago and it interacts well with the unit. The naming and configuration of the trailer information shows up on the 8.4 display just fine - so my programming is working as expected.
It just does not show the display / gain / etc... on the main cluster.
I have been through every setting and do not see anything else that might represent a trailer setting. Any thoughts at all?
I checked to make sure it was selecting the correct truck and defaulting the correct year... Check
I enabled the ITBM/HWM Integrated Trailer Brake Module
I enabled the:
- Trailer Selected CSM
- Trailer Name CSM
- Trailer Type CSM
Okay. In your first screen shot (ECUs) try using "Body computer: MY2019 PowerNet"
This is the one I used on the older version of the software from Feb. You are on the newest version that came out on Apr 9th. There may have been changes, but give that a try. Rest of it looks good.
Hmmm. That must be the new software update. The only difference I see is that forced ECU choice. Might be a good idea to shoot an email off the AlfaOBD and explain the issue. He is very responsive.I did, it automatically jumps to Var 3
Also, you could ask if you can download the version just before 2.1.6.0 (i don't know what it was but it is what I used when i did mine in Feb., and what I did the screen shots from in my post)I did, it automatically jumps to Var 3
By the way, I just notcied that I used "Body computer: MY2016-17 PowerNet" when I did mine (not MY2019). No matter, since it is forcing you to Var 3.
That's worth a try for sure.I can try that this evening - I would need to decide if I want go back to Var 3 and turn everything back off before I go into the 2016-17 and turn it back on... hmm
Yes, mine is the new body (5th Gen)
Please keep us updated as to the response from alphaobd. I have the same problem and am frustrated at this point much like yourself. Hopefully they have a solution or can provide a previous version for us to use.I reached out the alphaobd and and will see if he is able to find a solution - but I think it is safe to say that it is no longer possible to fully activate your brake controller DIY...
before people spend a bunch of money on software and security modules - I would wait for an update.
I will change my stuff back - call it a lesson learned, and take the truck into the dealership.
Did AlfaODB say anything about getting an earlier version that WOULD have used MY2016-17?So, again, at this time the system does not work. I have notified alphaodb and we will see if it gets addressed or not. His answer was... “hmm, should work...”
That said, it is no longer possible to DIY enable the brake controller at this time.
