nc_beagle
With the chip shortage, it will likely be a 2022 model, but I'll assume the bed choices are the same. Here are the details, if they help.
Below is a start on arguments in favor of each length. Please help me think of other things to consider. Note, the question marks indicate I'm not sure its correct.
5'7" Bed
6'4" Bed
Does anyone know how much payload you lose with the longer bed? That's pretty important to me. If we put our tongue weight at 12% and have the trailer at max weight, that's about 750# of payload consumed. We're not big people and our two traveling companions are beagles, but I'd like to have as much payload as possible--ideally 1350-1400#.
- We're getting a truck to pull a 24'9", 6200# max weight, travel trailer--a Lance 2075. Hope to be taking some long trips around the country.
- I'm going with a Ram 1500 because I like the truck and will use it for other duties, but nothing that would require a 2500.
- We currently have a 1996 F150 regular cab with an 8' bed and I love being able to carry a lot of stuff. But, I don't know about keeping the Ford just to have for the times I need an 8' bed--I have a 4' x 8' trailer I could use.
- Don't want the RamBox, which I believe is only available on the 5'7" bed.
- Will be getting a crew cab (Laramie) EcoDiesel
- Will get the air suspension
5'7" Bed
- More maneuverable/easier to park
- More payload due to slightly less weight?
- Shorter wheelbase for better breakover angle, in the rare case I get into an offroad situation where it's an issue?
- Shorter total length for RV campgrounds--though probably wouldn't come into play that often.
- I read elsewhere that the driveshaft is two-piece on the longer bed? (This was on the previous generation.) So, possibly fewer moving parts to break?
6'4" Bed
- More cargo room
- Longer wheelbase for better stability when towing?
- Bed extender would allow for items 8' long?
