I took the front of the truck apart and finally got to the headlight assy. Unfortunately the part that I received is for the passenger side. The PC Boards appear to be the same except that they are formed to the headlight. Passenger and driver are not interchangeable. I did try the replacement one and it did not work. When I turn my headlights on, the accent lights come on and then got out. I left the PC Board disconnected and turned the lights on and the accent lights did not come on at all. This leads me to believe that I am on the correct PC Board. The driver side is P/N 6002TZ0303. The passenger P/N is 6002TZ0304.
The PC Board I got was used but said it worked. I am only out $50 and I will see about getting my money back.
So now I have 2 options;
Options 1: Pay $200 for my deductible and have the headlight assy replaced by the dealer under my extend warranty.
Options 2: Get Demon Headlights from Oracle Lighting
Let me know what you all think.
Part# 1456-334 Introducing the 2019-2024 RAM 1500 ColorSHIFT® RGB Demon Eye Headlight Upgrade from ORACLE Lighting. This product is designed to fit RAM Models with the Factory LED DRL Option and Projector Headlights. These DRL boards can make hundreds of different colors, dozens of patterns...
www.oraclelights.com
Product Description Features What's Included Installation Part Numbers Introducing the Ram ColorSHIFT® RGBW+A Headlight DRL Upgrade from ORACLE Lighting. This product is designed to fit Ram Models with the Factory LED DRL Option and Projector Headlights. Featuring our new high-performance RGB+W...
View attachment 123666View attachment 123667
