- Jul 25, 2020
If you never drive your truck hard, or push it in corners, you may not notice much of a difference. Especially on a short drive. The truck definitely handles better all around with the Hellwig. Of course, I went straight to stiffest setting. Why install a better sway bar, only to limit the improvement it can give you? That would be like going rock crawling, after putting in new crawler tires, and leaving your tire pressure at 50psi.Just installed today. Went for a quick little ride. I really can’t tell any difference? I installed it in the middle, maybe I’ll try the stiffest setting. Like someone else said, it doesn’t feel bad just not much better?
