In heavy towing, on the 5.7L, you can see as high as 280F on the oil temps, coolant temps around 245F. Of course that's rather extreme cases of high load and elevation for an extended amount of time.
Your average oil temps should be around 210 - 230 range in most non-loaded applications with the Hemi. Coolant around 210 - 225F in those same conditions. But higher temps in heavier use is also normal.
There is a reason why manufacturers prefer the "dumb" gauges, which don't often show incremental temperature changes, only big movements. Its so it doesn't scare owners that see those fluctuations that normally happen, especially with coolant as it cycles from opening and closing the thermostat, which on many vehicles is over 20 degrees of fluctuations.
Despite what others may say, there’s no real benefit, but real downsides, to automotive lubricating oil being over 220deg. Yes, synth have more thermal headroom/margin, but I want to ensure my truck’s oil doesn’t exceed 240 (which it does under certain towing circumstances). Daily driving averages 200-210, peaks >240 towing: I’d be happy to keep the current daily ave temps, and just reduce the peaks to under 240.
So, current plan is:
- Moroso 23686 remote oil adapter
- Mishimoto in-line thermostat 200*
- unused oil cooler from a rally car project
- remote oil filter mount 22x1.5
- couple short and a couple longer -10AN braided hoses
Filter will go on pass. side frame, cooler will go either where the pass. tow hook would go, or just in front of the condenser. Should be fun...
