Thanks for your suggestion. I've never rotated tires on any vehicle I've ever owned in 35 years, but this is my first Truck. I only have 10800 miles. Tires still look brand new.
so It sounds like I need to accept this. my foot goes numb at those RPM 1700-2000. Such a nice truck except for this annoying issue!I’m told all V6 models vibrate and the uncomfortable vibrations felt through the steering wheel and pedal are normal and the vehicle is operating as designed. After two FCA Customer Care cases, no one has cared and tried to help resolve the problem. Good luck to those that are still trying to find a solution.
Yep - 100% agree. I’ve added a resonator in the mid pipe and bolted a bunch of damper weights to frame and exaust. It helps, but we shouldn’t have to deal with it. FCA or whomever should research and issue a TSB with a fix. We are stuck with something that definitely overshadows all the positives...so It sounds like I need to accept this. my foot goes numb at those RPM 1700-2000. Such a nice truck except for this annoying issue!
I have the exactly same issue on my 2019 Ram, did you get any feedback from the dealer? Curious your plan of action?Did you feel the vibration around 1800 to 2000 rpm or was it always 35 mph? My truck is smooth at 35 mph because it is usually at a low rpm at that speed. I feel the vibration as the rpm approaches 1800 rpm and is gone after 2100 rpm. Speed does not matter only rpm. I am trying to figure out if my problem is the same or not.
Same here. Dealer says it’s normal, but to learn how to say that is a requirement to work at a dealership. LolI guess I don't have a better way to describe this but lately I have been feeling the road or slight vibrations through the gas pedal. At first I thought it was the music or whatnot but with everything turned off I could definitely still feel it. Just makes the ride feel less smooth to me. Anyone have a similar issue or knows what I'm talking about?
Maybe the tires arent balancedJust traded (literally last night) my 2022 1500 limited because of etorque battery failing issues, recalls etc. New truck is a 2024 1500 limited, air suspension, night, etc. First thing I noticed on the drive home was vibration in the gas pedal and steering wheel.
This is just rediculous. Now a call to the dealer to deal with their we can’t reproduce BS if I had to bet.
Mine started at 0 miles and went away at 28,000 miles after a service (drive lines, brake fluid, and transfer case). I thought I resolved it. Came back at 30,000 miles. Engine also shutters and jerks back and forth when I tow my 5,000 lbs boat going about 30mph whenever I just started the truck or it’s chilly out.I had this problem for a few thousand miles then all of a sudden it miraculously disappeared. Have no idea why. I know this doesn't help but maybe there is a miracle in your future as well.
