Dank
- Mar 23, 2020
ThanksYes it will.
ThanksYes it will.
Does anyone know if these can be painted. I want to change mine to red
Yes, it can be paint, all the high lifted show truck paint them all the time.
Nothing i can just prep and spray on? Like performance enamel or something?Blast the powder coat that's on it and re-powder coat whatever color you want. Sanding it would be brutally hard, but doable.
Powder coating is slick hence paint doesn't adhere well, you will really need to scuff up the powder coat enough where the primer will be able to stick to the powder coat.Nothing i can just prep and spray on? Like performance enamel or something?
Sounds like too much work. Hellwig should offer colorsPowder coating is slick hence paint doesn't adhere well, you will really need to scuff up the powder coat enough where the primer will be able to stick to the powder coat.
