Exhaust Manifold Options
Dorman offers an updated design at a decent price.
That exaust manifold looks interesting. I hope they work out.
The factory manifolds have the load bars in the bolts. Now instead of breaking bolts, the manifolds themselves crack.
My manifolds were cracked, and the bolts were broken again for the 3rd time in 3-years. I ended up buying the BD manifolds and they are awesome. They are impressively built and significantly beefier with uniform thickness at all points. I am sure these will not be breaking on me.
Has anyone installed the BD manifolds on only one side without upgrading the other? I confirmed my passenger side is cracked on my 2020 with 64K miles tonight. The driver’s side is fine. Have our first baby coming in the next three weeks and not looking to spend more than necessary if I can avoid it. At the same time if the BD replacements are better I would rather buy for the one side and hopefully not have to replace the passenger side again. Otherwise I will be scrounging for an OEM replacement online, unless the allocation/supply chain issues have been resolved.View attachment 199930
I just installed the BD manifolds on my truck last night. They are insanely beefier and so much better built
Hi all,
Just purchased a 2019 Ram 1500 with the Hemi 5.7, and it has an exhaust leak (manifold). From what I've read this is fairly common, and likely to happen again with the stock parts every 30k miles (give or take). I'm currently still waiting for the dealer to get the parts in for repair (free of charge), but just curious what options are out there.
  1. Would these be the same as the original, or does 'performance' indicate it's an upgraded part?
  2. While I'm likely to let the dealer handle it this time, if I have to do it again down the road and want to keep the truck, what's the best upgraded option to avoid this problem again (or does one exists)?
Thanks in advance, I'm totally unfamiliar with these trucks/engines so learning on the fly.
Get BD Diesel. I just did mine this past weekend. Quality is so much better than stock.
That said, mine manifold had 10 bolts, and had two metal bars across the top and bottom bolts that acted like a spacer, similar to what BD does with each individual bolt, but they use a thick washer. I found that interesting because it seems that they were aware of the problem and tried to correct it. And all the videos I watched online showing the swap, not one had that metal bar across the top/bottom bolts
All 5th gens should have that bar. It was added after all the issues with the 4th gens and broken bolts.
Does anyone have hands on experience with the Dorman? I typically associate them with junk but willing to be corrected if others have better experience / knowledge. Think it is ridiculous this still happens given the maturity of this engine design.
I have installed a few sets. They are definitely an upgrade. Some early production had the wrong bolts in the kits. The bolts were not long enough, that should be taken care of now.
I ended up replacing mine with BD Diesel as well. My 2020 also had the metal bars between the bolt head and manifold as well, although the passenger side which was cracked on my Ram had the top bar split in half near the crack in the manifold.
Anyways I think I read somewhere that early production 2019s didn’t have the metal bars but was added sometime before 2020.
Overall a fairly simple install for me other than it being a lengthy process. No bolts were broken prior to removing the OEM manifolds although I did break one of the bolts that also holds the heat shield while removing the heat shield during disassembly. No big deal, just spread up the removal process really.
Glad a did the upgrade to the BD manifolds. They seem to be built very well and are much beefier than OEM. I feel pretty confident they will hold up for as long as I still have the truck. It’s too bad Ram hadn’t come up with a real solution to the problem as I felt this was inevitable even before I had my passenger side crack. Just glad to hopefully have this issue behind me now.
Thank you. If the manifolds crack and they are out of warranty I will see if the shop can install these. Looking at the photo they seem more
Robust than stock.
Anyone have any long term experience with the BD Diesel manifolds? My truck is at a shop getting these installed now. Wanted to do it myself but a few of the bolts looked broken flush with the block so I punted...... would love to know if anyone has put 50K+ miles or more on them without any broken bolts.
I'd like to know too. IIRC the consensus was that they are made better.
Anyone have updates on the BD kit? Both my manifolds are cracked, not sure for how long. Went in for cylinder misfire that they said was dirty injector and they found cracked manifolds. Quoted 1700 for repair, bought the truck used 60k miles ago and manifolds “aren’t covered under the full extended warranty”. Was considering buying the BD set and having and exhaust shop do it
I would recommend the BD manifolds and have a independent shop install, that worked great for me. I just got it done, so no long term experience yet. My thinking is…. If you replace with stock you will ultimately have to do it again. Theres a chance the bd manifolds are a permanent fix, and i plan on putting 250-300k miles on this truck. As mentioned by others, they are much beefier, but they also use longer bolts sitting on risers (supposed to allow them to handle heat cycle better) and independent bolts for the covers.
By the way, I got a killer deal on them from CSPRacing.com way cheaper than anywhere else on the internet and they delivered super fast. They responded to emails quick too, i was surprised how good the experience buying from them was.
I know this is an older post but has anyone tried these?
