Dusty1948
- Jul 14, 2018
- Location
- Rochester, New York
Wow @Dusty1948 agreed your mpg numbers are outstanding. Do you have a laid back driving style, in other words do you drive with an intent to get good mileage? 2WD, Quad vs Crew weights, and 3.21 no doubt helps a bit.
I normally drive sedate, and during the first couple of thousand miles I was breaking it in very easy. The actual mileage I got on the tank that was in my previous post was 23.06 mpg, hand calculated. The Miles to Empty figure is based on the results of the last tank. Doesn't mean that's what you'll get on the next. It's all how you drive.
My fuel mileage (hand calculated) to date is as follows:
20.18, 20.97, 21.95, 23.06, 20.90, 19.07.
On the fourth tank (23.06) I actually saw a current average of 27.1 on a 80 mile drive on state roads with speeds of 40-45 average, and never over 55. Unfortunately, my return to normal, around town and shorter trips the tank average dropped to 23.06 at the end.
I'm in an area with relatively flat to small, rolling hills. I'm also over 60 and retired, which translates to a much more patient driver.
Best regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 003603 miles.
