What I said was 100% correct. But you want to play semantics. Your recent driving habits are reflected in your recent driving history by default. There is no way around it. You can play word games all you want. Even myself, driving on the highway, making the same trip you make, we can end up with different MPG depending on our peddle and brake habits. Not sure why this is so complicated for you to understand, but changes to your driving habits will be reflected in the computers calculations because it will be a part of your recent driving history. If I am heavy on the gas peddle and brake and don't coast much, that will be reflected. The 2 things are related, it's not just by chance that the way you drive just so happened to get factored into and have an effect on the MPG and miles to empty. If you want to improve MPG and miles to empty, you can make adjustments to your driving habits and it will 100% get factored in because it is a part of your recent driving history. And my driving habits change daily depending on how much of a rush I am in.
Do you actually know what the word "habit" means?
Did you read your own post, where you said "
the computer hasn't had a chance to learn your driving habits"?
You didn't say "recent driving habits". You just said driving habits. Your habits are not something that just happened in your recent driving. And, your HABITS may not have come into play AT ALL in your recent driving.
Also, the truck's computer does not learn ANYTHING about your HABITS that it uses in calculating your DTE.
It ONLY knows how much fuel you used in the 500 miles (or whatever the specific number is), and uses THAT to calculate your DTE.
Your driving HABIT may be to hammer it from a light every time it changes to green. If you never did that in the last 500 miles (or 50?) then your HABIT exists and it is what it is. It is still your HABIT, but it has NOTHING to do with what the computer says is your DTE.
Crikey man! You said:
Also, if you just picked it up from dealership, the computer hasn't had a chance to learn your driving habits. So it's basing it's calculations on recent driving history, which includes in transit and at dealership start and stops.
You DIRECTLY implied that his driving habits would eventually be used to calculate DTE.
The intelligent thing to do when corrected would be to say "yes. My bad. Your driving habits don't matter. The truck is only going to look at how much fuel you used in the last XX miles to predict how many miles you've got left in the tank" and move on!
Read a dictionary. Look up "habit". I'm out!
