Yes de-pin helps a bit. The ANC algorithm is ****ed. It takes the noises it hears, and counter acts so called engine and outside noise with different frequencies! Bad part, this is also our musical system. To which counters acts what we hear to cancel unwanted noises. Sadly, it can gran audio sounds and try to cut them, or attenuate them. This system is nice, but needs its own speakers to actually work. Also, under the hood a vibration unit that works with the anc will give signals to cut out. Disconnecting the mics helps, a ton.. but this will also send information to ANC to cancel sounds.
Anyone have a picture of said unit. Supposed to be behind the battery. Or post a part number please. Removing puns is not hard. Pop up lock. Take a safety pin if you need, and push tab up, while doing, push pun in, and pull to release. Took 4 minutes to complete. Tape up wires
