I will chime in and say that i will not own another vehicle that does not "drive itself" on the highway at a minimum. Completely changes the game. I've logged over 20,000 miles on my C2 and absolutely cannot go back. It's interesting how much less tired you are when let the truck drive itself. Comma officially supporting is a big upside too. We should have full longitudinal control over the vehicle in a few months i predict. This will drastically improve the ACC functionality of the truck.
You might have to get a C3. I now am running steer to zero, and it is a game changer. Long will up the anti dramatically. Stop sign/light recognition will be a huge advantage.
I keep seeing these references to getting longitudinal control through Comma and I still don't understand why that's a big deal. The factory ACC is giving long control now, right?
I don't know how the factory ACC works when it's being controlled by a Comma, but when used all by itself, it works fine, to me. Well, let me re-state that. It works adequately. It has little foibles that I have learned to work around.
For example, if I catch up to a slower vehicle, it will slow down to match their speed. I move over to a clear lane and then it takes a couple of seconds before it starts to accelerate back up to my set speed. Is that something that having long control in the Comma is going to make better? And the "better" is just less of a delay before it starts to accelerate back up to speed?
To me, that is just not that big a deal. Mainly because if I let my truck slow down to match a slower car, I have already failed. I try to pay attention and notice when that is about to happen, so I can change lanes before my truck starts to slow down. Until the Comma can recognize those situations and do a lane change on its own, I'm not sure why having long control in the Comma, instead of just relying on factory ACC, is a big deal.
Help me understand?
I am ready to pull the trigger on this. I am a bit confused on this though. All I see is a Dev ket for Comma available to order. I don't see an option that isn't the dev kit. I also see someone else mentioned the cable is actually not available for our Rams yet so do I need to order that from
@Malodave here in the forum?
I went through the same questions you're asking about a week or so ago. Hopefully, this will help you some:
On the Comma website, they list a "car harness" and a "harness connector" for sale.
To me, a "car harness" would be the thing with all the wires and the connectors on the ends. A "harness connector" might be the same thing or it might just mean the molex connectors on the ends of the car harness.
That was all wrong, but it threw me off for a while.
In Commaspeak, the "harness connector" is what I would have called the wiring harness. The harness connector is the thing with all the wires and the molex connectors on the ends.
The "car harness" is a kit that includes the wiring harness (aka "harness connector"), and all the other stuff you need to install a Comma in your vehicle. I.e. the car harness is a kit that includes the harness connector, the harness box, the Comma power adapter, the USB-C cable, the CAT6 ethernet (aka RJ-45) cable, and a couple of mount plates (one of which gets "permanently" stuck to your windshield and then the Comma slides into it to be held up for use - plus one spare).
I think Comma would have made it all a lot less confusing for newbies like myself if they had just called the one thing the "wiring harness" and the other the "wiring harness kit". Anyway...
Comma does not currently have the actual wiring harness (aka harness connector) for our trucks. So, to install a Comma in a RAM, you can either spend $200 and buy a "car harness" from them for most any other vehicle (and have everything you need plus a harness connector that you don't need, but could possibly sell), or you can just buy the individual parts that you need - i.e. harness box, power adapter, RJ-45 cable, USB-C cable, and mounting plates, and save $20.
Whichever way you go, you'll still need a wiring harness, which Comma does not have for the RAM right now, but you can buy from
@Malodave. I think he's charging $20, with shipping for that part. And, if you do buy that from him, you might also consider buying his 3D-printed mirror mount, so you can mount your Comma that way, instead of having to stick something semi-permanently on your windshield.
As I said, I'm about a week ahead of you going down this path. Once I figured all this stuff out, I got on the Comma Discords (there's 2, a Comma one and a RAM OpenPilot one) and looked in the Comma for-sale channel. I picked up a used Comma 2, with wiring harness (for a Hyundai), for $500. I ordered the harness connector for a RAM (and a mirror mount) from malodave. When it all arrives (tomorrow, I think), I should be able to install it all in my truck, with no other purchases needed, load the right fork of OP, and start driving. Or, letting it drive me....
