bigdodge
Happy Ram Owner
- Aug 25, 2021
- Location
- southwest. where majority rules
anyone do an oil change after having this plate installed
no one?anyone do an oil change after having this plate installed
It's a fairly new product. Those who have installed one probably havent driven enough to need an oil change yet. I know my last oil change was over three months ago, and I do 5k mile oil changes.no one?
Super bowl weekend, plus was waiting on the fumoto valve that just arrived today. So this weekend oil change. Anything specific you are concern with.no one?
I use the dealer for oil changesSuper bowl weekend, plus was waiting on the fumoto valve that just arrived today. So this weekend oil change. Anything specific you are concern with.
I also use the dealer but this time I didn't trust them to install the fumoto valve without over tightening it or maybe they would be unwilling, etcI use the dealer for oil changes
what do you believe will they say?
yep I saw that lolno one is safe
Thieves Steal Oscar Mayer Wienermobile’s Cat
Thieves in Las Vegas cut the catalytic converter out of the Oscar Mayer Wienermobile as it sat in a parking lot overnight,www.thedrive.com
Did my oil changed on saturday, the dealer did a number on the oil drain plug and i struggle more than anticipated but the skeerdy plate doesn't get in the way. You can see in the picture it has an opening and all that is needed is a short extension. Not sure if a deep socket would do it. I didn't have one of that size on hand. If you will continue to use the oem drain plug then it won't be necessary to remove the plate. And doing your oil changes at the dealer shouldn't be an issue.I use the dealer for oil changes
thank youDid my oil changed on saturday, the dealer did a number on the oil drain plug and i struggle more than anticipated but the skeerdy plate doesn't get in the way. You can see in the picture it has an opening and all that is needed is a short extension. Not sure if a deep socket would do it. I didn't have one of that size on hand. If you will continue to use the oem drain plug then it won't be necessary to remove the plate. And doing your oil changes at the dealer shouldn't be an issue.
If you intend on installing a fumoto valve as i did then i would recomend you remove the plate, i did in order to tighten it since you can see in the picture what area you need to use to get it tight. And you can't do it with the plate on. Well maybe if you get creative but not sure the dealer would or if they wouldn't damage the valve by trying to tighten it from the wrong place.
I use the standard valve with the long nipple and it was perfect, i ordered a short nipple valve as well which i ended installing on my dad's jeep grand cherokee. I also used the zip lock bag trick on the oil filter and it work perfectly as well. A set of ramps from harbor freight gave me plenty of room and made things easier
Must be the new design to work with factory skid platesinstalled mine today
it weighs 28 pounds
only takes one person to install
put first two holes in plate on exposed bolts on truck
put on lockwasher and supplied nuts
lift up rear and install slip type nut and bolt
tighten down, doneView attachment 154401
ya that appears to be the only one they had, from american trucksMust be the new design to work with factory skid plates
Ramps sure help. I didn't get me a set until afterwards.installed mine today
it weighs 28 pounds
You have to remove it for oil changes?Ramps sure help. I didn't get me a set until afterwards.
Also keep forgetting to mention althought i don't think its an issue.
When i removed mine to do the oil change. I noticed marks from the sway bar since it is making contact
Ahh, okay, that makes senseDid so to be able to tighten the fumoto valve. I think a stubby would have done the job but don't have one. And also i was having a hard time removing the oil plug. So i could get some room and better leverage.
Otherwise there is no need
