I used Hyperdip from DipYourCar initially since I was unsure if I wanted to black out emblems, remove them, or leave them chrome. I followed instructions (taped off an area about 2" out from all edges of emblem, then sprayed multiple coats as instructed, then removed tape and peeled off excess spray) and for the 2 hood emblems, door emblems, grille, and tailgate emblems I spent maybe 1 hr total. Easy process as long as you follow the directions. After a little over a year I had 1 or 2 emblems where either I didn't put enough coats and a corner was barely showing or the peel had let loose on a small piece. At that time I bought a blackout emblem package (ebay - $88.88, included grill emblem, doors, ram head for tailgate and 4x4 emblem). They appeared OEM with OEM labels and adhesive. I just last month replaced the hyperdip emblems with those since I didn't want to worry about them peeling or fading. The Laramie emblem on the tailgate however seems much more expensive to find in black so I resprayed it with more hyperdip and it should be good even if I touch it up once a year.
