doolin64
Pair on eBay for $120 shippedAnyone recommend?
Doesn't the Rebel come with the upgraded UCA's?
Using the 2” Mopar UCAs on a Rebel set at circlip #5 will improve the Angles?.. I know with this setup, I’m at 3” total.
They're not that expensive and have more range than stock. I don't think it's a waste for the money.
What lift are you running? How are you going to be using it? Street queen (I'm including dirt roads on this on)? True offroading? That's important to know. You're posting in the Bilstein and Mopar lift threads.
From my research, Bilstein designed the struts to work with stock a-arms. So that means if you have a non ORP/Rebel/North/BTS truck, you can set them at the highest setting 2.6" and be fine with the stock a-arms. Adding the a-arms from Mopar will work in this scenario as well. Plenty of guys also run the Mopar lift plus ORP springs up front for a 3" lift and run the Mopar a-arms without issue.
If you decided to do Bilstein's at 2" and add 1.5" tophat spacer, or do any other combo for a 3-3.5" lift, then I'd suggest moving to a different a-arm. But it's not imperative, unless you're going to wheel your truck hard off-road and making out your droop going over obstacles etc. Again, this is just from my research.
There’s certainly expensive UCA options. Ready lift, rough country, etc. I found some Mopar UCAs on Ebay that come with the 2” Mopar leveling kit. But you can get just the UCAs for around 120 before tax and shipping. Just make sure you’re looking at the ones for the 2” leveling kit and not the stock moparsAnyone recommend?
I have the Bilsteins set to 5 with some Zone UCA's and am getting a similar clunk at full droop that is driving me nuts. Might be the shocks topping out. Did you resolve yours yet? I'm almost pulling the trigger on some extended Fox 2.5 coilovers..I would really hate to spend a couple thousand dollars on King Coilovers and still have the same problem.
+1What lift are you running? How are you going to be using it? Street queen (I'm including dirt roads on this on)? True offroading? That's important to know. You're posting in the Bilstein and Mopar lift threads.
Have you checked, retorqued/tightened to spec all your front suspension components, particularly front sway bar end links? When I was getting clunking that resolved it for me.I have the Bilsteins set to 5 with some Zone UCA's and am getting a similar clunk at full droop that is driving me nuts. Might be the shocks topping out. Did you resolve yours yet? I'm almost pulling the trigger on some extended Fox 2.5 coilovers..
So the ORP has the same lift as a Rebel, just smaller wheel/tire package? Does that mean when I was 'stock' I could fit the Rebel wheel/tire package on my ORP Longhorn?The UCAs are the same across the board as mentioned, the Rebel has different springs that I think are slightly stiffer, hence the 1" lift, though I think not even that is from just the spring, I think it's including the 33" tires as part of the 1" height difference.
*I have the Bilstein's on setting #2 w/ORP, so I'm sure I have the clearance now.
Thanks, I'll drive it a few miles and retorque everything.Have you checked, retorqued/tightened to spec all your front suspension components, particularly front sway bar end links? When I was getting clunking that resolved it for me.
