jl13
- May 28, 2021
- Location
- boyle heights, CA
what size tires are runningNot too many at moment but here's a cpl.
275 60 20 (33"). Stock was 32" so just went up 1"what size tires are running
thanks, great looking truck275 60 20 (33"). Stock was 32" so just went up 1"
I’m running this but also with a spacer up front. Very happy with the ride. Little rougher at times but it feels good. Also had a Laramie nonorp. Only complaint I have is I get some spring slap from the icon springs. If I knew this I would have gotten some coil sleeves and installed while putting them on.I have a 21 Laramie 1500 non ORP 4wd.
I believe I am going with Bilstein 5100's up front and Icon 1.5 springs in the back. Anyone running this? or think its a problem?
I should sit like a leveled ORP at the end.
did you need the front spacer? to much rake? pics of it without the additional front spacer.I’m running this but also with a spacer up front. Very happy with the ride. Little rougher at times but it feels good. Also had a Laramie nonorp. Only complaint I have is I get some spring slap from the icon springs. If I knew this I would have gotten some coil sleeves and installed while putting them on.
I had purchased the 2” readylift kit with UCAs to use. I essentially was looking to do a 3.5 lift using that kit and bilstein 5100s in front and adding 5100s and icon springs in the rear. I have about 1/2” rake currently. If the truck is sitting the right way it looks slightly nose high at times. I will eventually change out the rear to Clayton 2.5” rear springs instead. I went this route because I like the look more and wanted to run 35” tires. Tires fit well with this setup currently. I also wanted the springs to reduce the sag of the soft factory springs when loaded. The non orp truck did not handle a ton of gravel welldid you need the front spacer? to much rake? pics of it without the additional front spacer.
I am going 1" or 1.5" spacer in the rear with 2 inch Bilstein's up front. I wont be changing the rear springs.
