PatrickLeedleLee
Are there any decent dashcams that aren't hard wired? Not sure how feasible a battery operated one might be, but I really had any wires running around if I could avoid it.
Thanks, I'll PM you.Then you have something else going on there. Happy to help you figure it out if interested. There is clearly either something off in your settings or you have a bad camera. I have not seen any cameras with the issue you are referencing.
You can plug every dash cam into a cigarette lighter plug...none have to be hardwired. Hardwired is just cleaner looking and provides the capability for Parking Mode which is an essential feature. No standalone battery powered cameras. To hardwire a camera on a RAM takes like 15-30 minutes tops...SUPER EASY!Are there any decent dashcams that aren't hard wired? Not sure how feasible a battery operated one might be, but I really had any wires running around if I could avoid it.
All recordings are automatically saved to the micro-SD card until they are overwritten when the card becomes full. When an IMPACT is detected by a camera sensor, it locks that file on the SD card so it cannot be overwritten until you unlock the file. All dash cams work the same way for the most part. If you have more questions, feel free to ping me. If you want to manually save a video, you can find that video on the SD card via the app and save that file to your cell phone or lock it on the SD card.How do you manually save a recording on the Blackvue cameras?
The manual imply's to use the motion sensor to trigger a manual recording but if the unit is mounted behind the mirror, that doesn't seem very convenient to reach.
You can find battery packs meant for dash cams; Black Box My Car and Dash Cam Store both sell from. However, they are large (relative to the size of the dash cam) and are meant for keeping the camera running is parking mode (rather than using your truck’s battery) rather than while you’re driving. You still have to wire up the camera to the battery, then have a way to wire up the battery so it can recharge. So they are for a different purpose than what you’re looking for.I should clarify, I don't want any wires. That's why I'm looking to see if there's a viable battery option.
Not an option to do this at all.I suppose you could find a way to mount the battery close to your camera, and disconnect it to recharge it. I just don’t think you’d find that practical, though.
Then you MUST hardwire it...no other option my friend.I should clarify, I don't want any wires. That's why I'm looking to see if there's a viable battery option.
It wouldn't have the same features, or footprint of a dashcam but they do make wireless surveilance cameras that have been used in automotive scenarios before. Assuming you are even thinking of an automitive use at this point.I should clarify, I don't want any wires. That's why I'm looking to see if there's a viable battery option.
I have my dashcam wired behind my rearview mirror with an 8" wire.I should clarify, I don't want any wires. That's why I'm looking to see if there's a viable battery option.
You mean a battery that's independent of the car's power? I assume you plan to take it out and charge it at night? Not very practical. I mean, all you need is a USB cord and a Power Bank like this:Are there any decent dashcams that aren't hard wired? Not sure how feasible a battery operated one might be, but I really had any wires running around if I could avoid it.
do all ram models have this power in the mirror area or only the higher trims?I have my dashcam wired behind my rearview mirror with an 8" wire.
<iframe width="560" height="315" src="" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Just too be clear...this is a hack using this product. Will it work? Yes it will. It is a recommended approach? No, it is not. It is far too easy to run a wire in the these trucks to the fuse panel than to do a hack on the mirror...just my professional opinion. There are reasons why these are not used professionally.do all ram models have this power in the mirror area or only the higher trims?
so you would rather tear into a truck just to run a wire when you have this easy way to get power?Just too be clear...this is a hack using this product. Will it work? Yes it will. It is a recommended approach? No, it is not. It is far too easy to run a wire in the these trucks to the fuse panel than to do a hack on the mirror...just my professional opinion. There are reasons why these are not used professionally.
I’m semi-handy but not a professional at all, and I was able to easily hardwire a dash cam into the fuse box. I wouldn’t call it tearing into the truck at all.so you would rather tear into a truck just to run a wire when you have this easy way to get power?
it seems it is no difference then jumping a fuse or jumping a wire, just more clean.
what am I missing?
maybe this is your way of running up the labor tab.
better explanationI’m semi-handy but not a professional at all, and I was able to easily hardwire a dash cam into the fuse box. I wouldn’t call it tearing into the truck at all.
Hardwiring a front cam takes maybe 15 minutes, or less. A rear cam is more challenging and time consuming, but this mirror adapter isn’t going to help with a rear cam anyway.
Maybe there is or maybe there isn’t harm in using such an adapter; I don’t know. But I do know that it’s not difficult to wire into the fuse box for a front cam, so I wouldn’t be weary of giving it a go.
Explain how putting an adapter behind the mirror is a hack. What are the reasons these are not used? But running a wire, up the headliner, down the pillar, under the dash, and into the fuse box with a hard wire kit is not a hack?Just too be clear...this is a hack using this product. Will it work? Yes it will. It is a recommended approach? No, it is not. It is far too easy to run a wire in the these trucks to the fuse panel than to do a hack on the mirror...just my professional opinion. There are reasons why these are not used professionally.
I just want to mention, most recent vehicles I've owned have either had a sunroof, compass mirror, auto-dimming mirror, or some sort of electronic device in the front headliner that is only powered when the key is in the ignition. Most dual (F&R) dash cams run 0.2-0.4A, they're not going to fry the circuit. I simply take out the front map light, look for any switched +12V, and a decent ground terminal/screw. I'm not a licensed installer of anything, but I'm the closest thing and an Engineer. I've wired my own car alarms, I've wired my own race car harnesses, so I am FAR more trusting of hunting down my own wires and tapping using a quality device.Just too be clear...this is a hack using this product. Will it work? Yes it will. It is a recommended approach? No, it is not. It is far too easy to run a wire in the these trucks to the fuse panel than to do a hack on the mirror...just my professional opinion. There are reasons why these are not used professionally.
See above.so you would rather tear into a truck just to run a wire when you have this easy way to get power?
what am I missing?
