Idahoktm
To put this figure in perspective, the 2.0-liter in the latest Subaru Crosstrek maxes out at 145 lb-ft.
Unfortunately, it's only good for the first 1/2 tire rotation.
Battery too small, belt too weak to ask for more. I still marvel at how minimally invasive this MGU setup is for what it does. A Star Trek's Scotty-worthy mash-up job.
Possibly. I’m thinking of a thread where someone was saying ET hemi was gas hp + ET hp. Maybe it was torqueMaybe you're remembering the torque figure. eTorque can add up to 130 lb-ft of torque.
Once again, it's not more friction on anything. The little electric motor does not make the pulley tighter. It puts out 16hp. It turns or it does not is irrelevant. It just does not turn if the force on it is greater than its power.
More than likely a cheap POS belt used on a system that would benefit more from a decent tune on the 5.7 gas motor than adding a little electric one to it.
Maybe it identifies as a hemi?!Shoot, put gears on that little 16hp motor and get rid of the belt. It will drive the truck all by itself, it has unlimited potential! Careful not to twist off an axle with all the power pouring off of that thing. It has way more power than that little hemi any day.
Looks like you are correct!Unless the etorque belt changed for 23 and 24, we need to be careful in getting the correct belt.
None of the auto parts places I called can cross reference the apparently correct Mopar 5281957aa.
Some say its 6 band, but it could be 8 band. Almost all the part numbers given in this thread except the Mopar are narrow belts at 13/16" wide.
The belts on 23s and 24s are 1 1/8" wide. Not sure on 19-21.
Best I can tell is if you need the wide belt you want a Gates K080730 or a Dayco 5080730, or the Mopar.
Appears that due to the relative newness of this belt no auto parts place i called can tell you what you need.
From looking up the Mopar, Dayco, and Gates belts, there appears to be a different part number for the '23-24s ETorque belt, so it looks like Ram acknowledged the issue and changed the belt width starting in 2023(?).It just about confirms that Ram realized the narrow belts were too weak and failing too often and that how we got the 1 1/8" width.
It would help many others to know in what year the change occured.
I plan to carry a spare belt for each in my 24 Laramie, asap.
And you’re sure the different belt part numbers aren’t just V6 eTorque vs V8 eTorque? The Mopar part number for my 2019 HEMI eTorque is 5281514AA.From looking up the Mopar, Dayco, and Gates belts, there appears to be a different part number for the '23-24s ETorque belt, so it looks like Ram acknowledged the issue and changed the belt width starting in 2023(?).
I missed this PN change (and didn't physically check my own truck), so figured "DT is DT" and bought the wrong K060730HD (6rib) initially, but thanks to your insight (and me looking at my belts), I now have the K080730HD ordered from Rock Auto on the way..Thanks!
My bet is that '23-24 owners won't need them or have an issue, but they are cheap insurance.
Interesting!And you’re sure the different belt part numbers aren’t just V6 eTorque vs V8 eTorque? The Mopar part number for my 2019 HEMI eTorque is 5281514AA.
Yeah…they’ve been 8-rib all along, at least for the V8s. That’s what got me wondering.Interesting!
No, I can't verify that unfortunately. There is little to no info on the Mopar belt to compare it to others.
When I searched and ordered the Gates K060730HD, it did show that it fit the '19-22 Ram 5.7 ETorque engine(but how often do sites have wrong info, right!)..I just assumed at the time that like very often, the '23-24 DT would use it also and that the site wasn't updated to those years yet.
The Gates K060730HD and K080730HD belts are basically the same except that they are 6rib and 8rib.
My 5281514AA is an 8rib belt..the one on your '19 must be also(?).
A quick look up Mopar parts store confirms this part number is for 2019-2024 "5.7L V8 - Electric/Gas, 5.7L V8 - Gas."And you’re sure the different belt part numbers aren’t just V6 eTorque vs V8 eTorque? The Mopar part number for my 2019 HEMI eTorque is 5281514AA.
