Convert newton meters to foot pounds - Conversion of Measurement Units
Do a quick conversion: 1 newton meters = 0.73756214927727 foot pounds using the online calculator for metric conversions.www.convertunits.com
10.5Nm = 7.75 ft/lbs
10.5Nm = 92.92 in/lbs
I torqued to 10.5 Nm
Ok. So after eating $64 on a torque wrench that could go low enough (9nm) I overtigheted a few screws and they either stripped or popped inside.
I pulled on the rails pretty hard and they stay in
Is this going to affect the install at all?
It's pretty hard to have issues with the supplied rivnuts/nutserts if you put them in as the video shows. Just modify the procedure slightly by using a boxend wrench to hold the bolt and lube the threads and washers before using them.
I did better on line than 300. The rivnuts are hexagonal and I had no problem what so ever, take your time.Thank you for the video. That makes sense. IS there anywhere you recommend getting these rails? Directly from the dealer, they quoted me almost $300 which I thought was a bit steep.
I don't know the limitations of the rails as far as rivnuts. There is a posting by one member that used fender washers instead of the rivnuts.Authentic Mopar Pickup Box Utility Rails 5.7 Bed - 82215285AB | Mopar Online Parts
Get Authentic Mopar Pickup Box Utility Rails 5.7 Bed - PN: 82215285AB online! Browse affordable genuine parts at MoparOnlineParts & save up to $28.08. Buy Now!moparonlineparts.com
I have not seen a forum member with a posting on bed rail failing under load and the directions does not list a load limit.
The rails are attached at 8 points and you have tie down points at front and back of the bed. You can also add bullrings to the top of the rails. Adds up to a lot of secure points.
Here's where I got mine. $208.06Thank you for the video. That makes sense. IS there anywhere you recommend getting these rails? Directly from the dealer, they quoted me almost $300 which I thought was a bit steep.
I also got mine from my dealer, about $225 IIRC. I used a coupon from the dealers website that was 15% off. Go through the MOPAR/Ram owners website and look for your dealer. That's where I found the coupon. My dealer seems to be less than list by a few bucks and they took the coupon too. You can check the vendors on this site and on Ebay also.Thank you for the video. That makes sense. IS there anywhere you recommend getting these rails? Directly from the dealer, they quoted me almost $300 which I thought was a bit steep.
Looks like really good pricing and shipping. The 5" 7" is 189.88 and shipping to my local is $23.02.Here's where I got mine. $208.06
DODGE RAM 1500 DT 5th Gen Pickup Box Utility Rails Conventional Bed 82215286AB | Bam Wholesale Parts
Buy Your OEM Mopar 82215286AB Pickup Box Utility Rails RAM 1500 DT 5th Gen 6'4" Conventional Bed (2019-2024) Mopar OEM (82215286ab) Online For Your 2019-2025 Ram 1500 Vehicle And Have It Delivered Right To Your Home or Work!www.bamwholesaleparts.com
The rivnuts that come with the rail are terrible. Half of them either just spun (wouldn't crush) or crushed partially and popped back out of the hole. I ended up having to buy my own rivnuts and tool to mount the rail. In the end I still don't have confidence in it. I would rather have actual nuts/washers on the opposite side of the bolts but that requires removing body panels or what not.
Amazon.com: REXBETI 14" Auto Pumping Rod Rivet Nut Tool, Professional Rivet Setter Kit with 7 Metric & SAE Mandrels and 70pcs Rivnuts, Upgraded Labor-Saving Design, Rugged Carrying Case: Home Improvement
Buy REXBETI 14" Auto Pumping Rod Rivet Nut Tool, Professional Rivet Setter Kit with 7 Metric & SAE Mandrels and 70pcs Rivnuts, Upgraded Labor-Saving Design, Rugged Carrying Case: Riveters - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Amazon.com: 40pcs M6 Rivet Nuts Stainless Steel Threaded Insert Nutsert Rivnuts M6-1.0 Threads Nuts: Home Improvement
Buy 40pcs M6 Rivet Nuts Stainless Steel Threaded Insert Nutsert Rivnuts M6-1.0 Threads Nuts: Rivet Nuts - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
So I have the rails and bolts from my truck I traded, but the new truck needs the rivvnuts I guess. Is the tool required to install them? I'd rather not spend $60 on a tool I'll use once.The rivnuts that come with the rail are terrible. Half of them either just spun (wouldn't crush) or crushed partially and popped back out of the hole. I ended up having to buy my own rivnuts and tool to mount the rail. In the end I still don't have confidence in it. I would rather have actual nuts/washers on the opposite side of the bolts but that requires removing body panels or what not.
Check post #8 in this thread.I have the rails and bolts from another truck, but apparently there is no way to buy the
Does anyone know what size the rivnuts are? I talked to the parts guy the other day and he had no idea and didn't seem to be interested in helping me find out.
I'd like to use the holes and the rivnuts but attached a couple of quick fists for a shovel and axe. Don't need the whole bedrail system
