Please let us know how that bds kit work out…thanksOrdered my 4inch air BDS kit in 1st week of August still waiting. Called BDS they said it could take up to 10-12 weeks. Which puts my new ETA between Oct 16 to the 30th.
Curious how your engine and transmission have performed with the lift and tires. I'm debating whether to lift my 2020 Limited EcoDiesel or switch to gasoline truck. Have heard reports of EcoDiesel not staying in 8th gear on highway. I experience substantial turbo lag with base 22" wheels and tires. Hesitant to make the investment for fear of future performance issues.9200 miles in on my RC 5” lift and absolutely zero complaints or issues. I will say that I have the EcoDiesel and used the 22” wheels in the black Appearance package. I just installed 2” spacers and this causes rub. A 22x10 rim may be safe but wanted to mention this for the OP. No rub in OR2. Slight rub on hard turn in OR1. Rub in Normal or below. I have a limited and diesel totally loaded so probably the lowest payload if that contributes at all, and for what it’s worth.
I think your gear ratio is the biggest factor. 3.92 not so much falling out of 8th. 3.21, expect it more often with bigger/heavier wheels and a lift.Curious how your engine and transmission have performed with the lift and tires. I'm debating whether to lift my 2020 Limited EcoDiesel or switch to gasoline truck. Have heard reports of EcoDiesel not staying in 8th gear on highway. I experience substantial turbo lag with base 22" wheels and tires. Hesitant to make the investment for fear of future performance issues.
IS this sitting all the way up at OR2? I have the same exact truck and am searching around for lifts right now.I have 2020 limited with air ride, went with RC lift, ride greatView attachment 67675View attachment 67676
I have basically the same truck and lift, and that is absolutely OR2.IS this sitting all the way up at OR2? I have the same exact truck and am searching around for lifts right now.
Thanks brother, how do you like the lift? Any issues with getting anything covered under warranty? Heard lifting will void warranty for the powertrainI have basically the same truck and lift, and that is absolutely OR2.
Sent from my SM-F926U using Tapatalk
I've not actually had to do any warranty stuff for the powertrain, so I can't speak to that. I also use a pretty great dealer in VA called Safford, and they haven't said anything other than "nice truck".Thanks brother, how do you like the lift? Any issues with getting anything covered under warranty? Heard lifting will void warranty for the powertrain
Whoever told you that a lift will do a blanket void of the powertrain warranty doesn’t know what they’re talking about. For any repair, a dealer will have to prove something aftermarket caused a failure to particular component for it to not be covered. Lifts have almost zero to do with the powertrain. Maybe if the driveshaft was extended and IT failed, there might be a case. But suspension is suspension is suspension. Obviously replacing suspension parts will affect factory suspension component warranty - and that should be it. Look up the Magnuson-Moss Warranty Act…Thanks brother, how do you like the lift? Any issues with getting anything covered under warranty? Heard lifting will void warranty for the powertrain
Congrats! How did it turn out?? Id be interested to see some before and after pictures! Also, how did it affect your MPGs?Just got the call today Kit (BDS 4inch air ride) and Tires (35X12.5R20) are at the shop! Soonest they can get me in is the 15th! ALMOST THERE
I will let you know when its installedCongrats! How did it turn out?? Id be interested to see some before and after pictures! Also, how did it affect your MPGs?
I will let you know when its installed. Date was set for the 15th of last month. Showed up on 11-15 shop opened up the kit and BDS sent out the WRONG knuckles! New install date is set for 12-16.I ordered this kit back in august and the shop is an hour and a half away from where I live. Kinda sucks but driving there back and forth and the wait I'm just what ever about the kit now lol. Im 1000% sure millage with take a hit, but then again I bought this truck to haul my bikes for track days not a daily driver mpg beast.
This was my first truck purchase I have ever had so I test drove the 20 raptor,20gmc denali, ect ect the ram limited was the clear winner in my option for the purpose I was looking for. The air suspension and the way it rode was one of the things that made it stick out to me. I dont see a lot of members having issue with their air suspension even the ones on leveling links. Im curious was what issue the ram service manager is referring to, are you going to be doing to be doing major off roading? I am curious to see how an air sus ram will do in a decent trail.I'm very curious to hear how you like this lift and the choice of keeping the air suspension. I've got the invoice for replacing the air suspension with a Zone 6" lift with and Fox 2.5 coil overs (with wheels/tires), but I'm trying to do all my research before I pull the trigger. I would like to keep the air suspension, however, after speaking with a Ram service manager and him explaining how many trucks are having issues with almost all aspects of the air suspension, it concerns me that it may just be a matter of time for my truck. Hmmmm...what to do, what to do.
I've always been curious how much of a difference the hellwig would make for people with the RC 5" lift. One of these days I'll probably just have to pick one up.I have heard nothing but amazing reviews on air ride rams with either the 4inch bds or 5inch RC lift. Most people are saying its a little bit stiffer ride after the lift maybe that will give you the more solid ride your looking for? Have you looked into a hell wig sway bar upgrade? For me I absolutely love the way the air ride on the truck. it def gives it a better ride than any other trucks with coil over set ups that I have tested.
I have had not heard one bad review with either 4inch BDS or 5inch RC lifts on any air ride 5th gens so far. Like you said the stiffness can always be mitigated and also subjective based on Tire brand, tire psi that person is running/ tire size combo. So many factors needs to be considered as well and that can be adjustedI've always been curious how much of a difference the hellwig would make for people with the RC 5" lift. One of these days I'll probably just have to pick one up.
I would also add that any additional stiffness after the lift is marginal at best. Still a very nice ride.
