What’s the software version on those?
Not sure. I will try and ask.What’s the software version on those?
Here’s something from another thread. Search ‘centerline’.
Ok ok. We have established that the 12" screen with tow group has the line. The 8.4" screen with and without tow group has the line. So if you have those then there is no need to inform everyone that you have the line because we already know you do. We have also established that the 12" screen without tow group (with 360 camera) does NOT have the line. So if you have a 12" screen without the tow group and WITH 360 camera and you DO have the line, please comment because then we will see that there is a discrepancy.
Was it covered by the warranty?My dealer just called and just got my centerline working on my 12 with surround view. It isn't a software update. The dealer had to change out the CVPM which is "camera view something module". I will have more info when I pick up the truck but I now have a centerline!!
Yes it was.Was it covered by the warranty?
And it definitely was the CVPM?Yes it was.
Thats what the dealer claims. They tried changing the camera, didn't work, changed the radio, didn't work, changed some harness, no good. Finally they opened a star case and Ram told them to change to the CVPM and it worked. Just a note, the out my original camera, radio, etc back in. I think it was trial by fire for the dealer.And it definitely was the CVPM?
Understood. I’ll defi be looking into this whenever I take mine in.Thats what the dealer claims. They tried changing the camera, didn't work, changed the radio, didn't work, changed some harness, no good. Finally they opened a star case and Ram told them to change to the CVPM and it worked. Just a note, the out my original camera, radio, etc back in. I think it was trial by fire for the dealer.
Do you know where the CVPM is located? Just want to know if it's an easy swap for the dealer or if it requires radio removal...Thats what the dealer claims. They tried changing the camera, didn't work, changed the radio, didn't work, changed some harness, no good. Finally they opened a star case and Ram told them to change to the CVPM and it worked. Just a note, the out my original camera, radio, etc back in. I think it was trial by fire for the dealer.
I forgot to ask if this is something we are all supposed to have or is it for certain build dates? I want to be educated about it before I take mine in to the dealer.Do you know where the CVPM is located? Just want to know if it's an easy swap for the dealer or if it requires radio removal...
Great info. Thanks much.I took mine in and told the dealer about replacing the CVPM to get the center line working. While troubleshooting the issue, the camera crapped out on them so they replaced it, but like yours that didn't resolve the center line issue. They opened a Star case and are waiting to hear back. Do you have your Star case number by chance so I can have them reference yours and get mine taken care of?
My truck is in right now for recalls, etc., and I've asked about the centerline. Do either of you have the STAR case numbers that I can relay?I took mine in and told the dealer about replacing the CVPM to get the center line working. While troubleshooting the issue, the camera crapped out on them so they replaced it, but like yours that didn't resolve the center line issue. They opened a Star case and are waiting to hear back. Do you have your Star case number by chance so I can have them reference yours and get mine taken care of?
@grinch72, my dealer declined to address the missing centerline. They stated that they went out on the lot and looked at one or more trucks with similar options to mine, and the 12" UConnect with surround view cameras doesn't show a centerline on those trucks either.My dealer just called and just got my centerline working on my 12 with surround view. It isn't a software update. The dealer had to change out the CVPM which is "camera view something module". I will have more info when I pick up the truck but I now have a centerline!!
i had a Ram cares case. Not sure if that’s the same as a star case. I will try and find that. Also tell your dealer he’s full of crap. You can find 100 longhorns online with 360 and the centerline. Luckily my dealer had trucks like mine on the lot that had the line.@grinch72, my dealer declined to address the missing centerline. They stated that they went out on the lot and looked at one or more trucks with similar options to mine, and the 12" UConnect with surround view cameras doesn't show a centerline on those trucks either.
They could find no STAR cases applying to trucks equipped like mine. The service manager did say that if I could give him a case number, he'd be happy to take a look. If you have yours or could get it for us, it would help out both @jloops and me.
