Hello,
I am currently wiring up some grill lights on my 2023 Rebel with the LED headlights. The off-road lights I am installing have a DRL “halo” function. I want the halos on the off-road lights to come on with the DRL headlight strips that come on whenever the engine is running but I’m running into an issue. I have everything wired through a relay with a positive trigger and I have the white/orange wire already tapped from the plug that goes into the headlight housing for the DRL strips. I already checked the voltage of the headlight wire that I tapped and it read 12.5 volts. But when I plug it into the trigger port on the relay, nothing happens. I ran a dummy wire from the positive terminal of the battery (same voltage) to the positive relay trigger and it fired just fine. I’m confused as to why this will not trigger the relay with my DRL wire. I have also verified the wire colors through another thread on this forum from 2021 but I’m not sure if it’s any different being that this truck is a 23. If anyone has experience in doing off road lights with relays then that would be appreciated!!
