HEMIJAKE
That's what I've always thought too.As long as you run good quality oil and change it regularly, there probably isn't any measurable difference.
The engine sounds like nothing out of the ordinary and you call that a problem and that the factory weight oil is incorrect. You sound delusional. Then you think that based on your experience hauling your groceries home every Friday, that me, already towing the same 7k# trailer over 125k miles with Hemi engines don’t know what I’m doing by following the Factory Service specs.
Like I wrote earlier, your advice is poor with nothing to back it up but your opinion of what you think you hear. You should try spending more time behind the wheel listening to the sound system instead of under the hood listening to the engine imho.
They haven't used a 5.7L in the 2500/3500 truck in how many years?I don’t understand why Ram would publish the 30-weight requirement for 14k+ lbs GCW if oil weight didn’t matter
NOTE: For 2500/3500 trucks with a 5.7L engine operating under a gross combined weight rating of 14,000 lbs (6 350 kg) or greater, SAE 5W-30 engine oil is recommended for all operating temperatures.
2017 3500 5.7L is the same as a 2022 1500 5.7L?2018 was the last year... current version of the 5.7L has been around since 2009
Didn't you just start another entire thread where you are listed at MR 5w20 cause they put in 5w30?My dealership put 10-30 in my truck without advising me. I read the invoice and had them re do the oil change. Two oil changes later they did the same thing!!!!! Now my name in their computer is MR 10w 20!!! Use what the owners manual and oil cap say. And eat your peas and carrots. And if you Google the Twitter to much you will go blind in the one eye!
Still getting used to the site? I thought that was a reply to somethingDidn't you just start another entire thread where you are listed at MR 5w20 cause they put in 5w30?
Similar but not the same.Yes, only difference is the tune and MDS
P1521 is a code that can set. It's odd I know.The 2500 5.7 does not have MDS.
In the user manual for the 1500 5.7 they said (paraphrasing) 30 weight oil may prevent MDS from working. Nobody running RL 5w-30 or 0w-30 has ever reported problems with MDS not working, it's a non issue in reality.
There is no such language in the manual. As a matter of fact, I can't find any reference to MDS in the owner's manual.The 2500 5.7 does not have MDS.
Some vehicles with the 5.7L have the warning in the owners manual, some don’t. There is no consistency.
This is the only reference to MDS in the 2021 manual.Some vehicles with the 5.7L have the warning in the owners manual, some don’t. There is no consistency.
