- Jul 25, 2020
Same here with 35" tires.I'm a out 2k at 80mph but I have 35s. Your Reble has 33s right?
Yes, the stock 275/70/18 is just a hair larger than a 33x10.5 tire.I have the stock size but replaced with KO2's. So probably 33's.
You better have your CDL if you’re hauling loads like that!Holy crap, I could barely get out of the parking lot with this trailer!
Better hope a breeze doesn't catch that massive sail and push you backwards!Holy crap, I could barely get out of the parking lot with this trailer!
So what rear is the better option for the 2025s? Since we know the 3.21s are superior for all but the narrowest margin of circumstances in the current year and older 5th Gens, does the new engine and transmission setup change that fact for the 25s?
Hey @spyder I saw the misspelling in your post. Yea, spellcheck doesn't pick up on the fact that using superior in conjunction with 3.21 is both grammatically and factually incorrect. I fixed this for you just in case a newbie read it. We wouldn't want to mislead anyone. Well unless they are buying it as a sweet 16 present for thier daughter.So what rear is the better option for the 2025s? Since we know the 3.21s aresuperiorinferior for all but the narrowest margin of circumstances in the current year and older 5th Gens, does the new engine and transmission setup change that fact for the 25s?
BMTHAA (Big mouth tiny hands and arms) speaks again….It looks like Ram has concluded that 3.21 gears are inferior. You can't order a 2025 with the I6 Hurricane and 3.21 gears.
This configuration 3.21 is only available in trims Laramie and under AND 4x2 for hurricane
Big Horn and Laramie in 4x4 are either 3.55 or 3.92 (no choice of 3.21)
Rebel, Limited trims and up are automatically 4x4 and 3.92
I forgot that you always have to have the last wordIs a Laramie 4x2 with the Hurricane I6 not a 2025?
I am aware of the 4x4 and Limited/Longhorn/Tungsten options but that wasn't the comment
No, you jumped in assuming something and were wrong.I forgot that you always have to have the last word
I didn't bother looking at 2x4 trucks. They are useless where I live.
