Mountain Whiskey
- Mar 2, 2021
I usually prefer 10 round groups, but TAC, SMK, and primers aren't as easy to find these days.Love to see 5 shot groups.
Very first thing to do is make sure your ammo is correct to the barrel twist rate. Believe it or not. it can make a difference.My Marlin 30-30 lever has a scope on it dialed in at 500 feet. I can keep a 6-inch pattern as long as I am properly stabilized.
My Henry's are all with the factory iron sights (also large loop levers) so accuracy is shorter range but they are carbines. I typically shoot 100 to 150 feet with the .44 mag and .357 Henrys and hold a nice pattern. The Henry .22 large loop lever I run at 50 feet and it holds a nice pattern.
My .223 seems to have an accuracy issue that I don't understand. I've taken it to the range and had a couple of different range officers give it a try and they didn't understand it either. I'm thinking after a few rounds, the barrel heats up causing the issue. May be time for a new one before the loonies ban them.
It could be just me but once you run a Henry lever action, you can't go back to a Marlin or Winchester. The Henry's are just that smooth and now that they offer side loading in addition to tube loading, the only reason not to get a Henry is that they are next to impossible to find.
Does your inaccurate AR15 have a scope on it?My Marlin 30-30 lever has a scope on it dialed in at 500 feet. I can keep a 6-inch pattern as long as I am properly stabilized.
If you started a scope thread it may be contentious as many have widely varying opinions on them, but I would like it. I would love to hear your opinions as well as others to help me learn more. One thing I have learned is that you can spend more on a scope than a rifle. Much of that can depend on its intended use too.Does your inaccurate AR15 have a scope on it?
I have had a good amount of scope failures in my lifetime. A few being knocked off zero, measured in feet. And several that were not repeatable (all over the place), and one that was an obvious failure with canted crosshairs. So, if you do have a scope on it, try a different one. I do have strong opinions on scope manufacturers, but that is for another discussion maybe. It sounds like you just plink with iron sights though.
If you want to start a new thread on rifle scopes, I will comment more, and I would like to hear different opinions on them also.If you started a scope thread it may be contentious as many have widely varying opinions on them, but I would like it. I would love to hear your opinions as well as others to help me learn more. One thing I have learned is that you can spend more on a scope than a rifle. Much of that can depend on its intended use too.
308, 300 or 223? I love my remi 710 30-06. Holds 1" @200yrd with 185gr. I have not adjusted the scope since 2006. Most consistent and durable I have ever seen. I did 'float' it right after first time firing it.Bone stock Rem 700P LTR, Leopold MK IV LR/T 3.5-10x40, 178gr GMM factory loads
I screwed up, it wasn't my AR15, it was my Mini 14 that had the drifting accuracy issue. I sold that rifle a while back. My AR is just fine. Sorry for the error.Does your inaccurate AR15 have a scope on it?
What are you doing posting while on vacation…308, 300 or 223? I love my remi 710 30-06. Holds 1" @200yrd with 185gr. I have not adjusted the scope since 2006. Most consistent and durable I have ever seen. I did 'float' it right after first time firing it.
Vacation? Spent the last two weeks moving to knoxville. I don't get vacations (retirement means every day can turn into a honey-do day if not carefully managed. I usually attempt to get greasy or covered in some animals guts before she wakes)What are you doing posting while on vacation…
Sorry, 308WIN308, 300 or 223? I love my remi 710 30-06. Holds 1" @200yrd with 185gr. I have not adjusted the scope since 2006. Most consistent and durable I have ever seen. I did 'float' it right after first time firing it.
