19llhpb
Here it is, all accessorized! 2019 Longhorn (truck details in my signature)
3 1/2” Rough Country lift (actuall 3 1/2” front 1” rear), Mayhem 20x9 8103 wheels ( 0 offset), Amp 35x12.5 Terrain Gripper A/T tires, Express roll up tonneau cover, AVS smoke colored bug deflector, AVS smoke colored in channel window vent visors, 12x18 rear mud flaps, front mud flaps, front door window tint 20%, windshield brow tint 5%.
Absolutely love it! Looks like a truck now. The ride is surprisingly still very nice. With tires and lift the front is 5 1/8” higher than stock, the rear is 3 1/8” higher ( measured on level concrete floor before and after). Even with the lift, I did have to trim some of the plastic and zip tie it back on the lower back of the front fender wells to get the 35’s to not rub when turning. They clear by about 1/8”. With the 0 offset wheels it does provide a slightly wider stance. I didn’t want to go to aggressive. I believe stock wheels are around +17 or +18 offset. The tires are 10 ply but only have 40 psi air. Would have liked the rear end to sit higher with the lift, especially when I tow my trailer. I know it may effect the ride, but thinkin about adding in coil rear air bags which will be available in late August for the ‘19. I figured no matter what I do, it will still ride better than my 2010 3500 shortbed did!
Also, adjusted my headlights and we are good to go!
Update: 1-20-2019 I did add rear coil air bags and also swapped the 1” block for the rear coils that came with the RC lift with a 2 1/2” block from Southern Truck. Has more of a rake to it now, the front no longer seems too high!
Update 2-26-19
Drilled hole through rear lift block for airline for airbags when installed. After many tries and tweaks the air line keeps pinching, cannot get to work. Removed bags.
Update 2-26-19
