2019REBEL
I have a 2010 with a 4" lift. I have been using Total load Control Bags. They work great. Much more expensive than the ones that go in the coil, but worth it
Its too bad they went out of business.
I did not know that. I did find this on this forum today. Looks exactly the same as what I have. Should be a great fitIts too bad they went out of business.
I've got 20% tint on my front windows and in channel vent visors on my 2019. Haven't had a problem. Ran the same setup on my 2013 for 4 years. If the tint install is good and its fully cured it won't be a problem.
With the window tint being on the inside of the glass the vent visors have no affect on it whatsoever. The in-channel visors fit nice and tight in the window channel on the outside of the window. Also, the windows are not tinted all the way to the edge of the glass, it is roughly a quarter inch from the edge leaving room for the inside rubber trim when the window is all the way up. Hope that helps!
I cannot believe I find Patriot Blue with RV Match Walnut Brown so @#&$ing sexy... your truck looks awesome.Here it is, all accessorized! 2019 Longhorn (truck details in my signature)
3 1/2” Rough Country lift (actuall 3 1/2” front 2” rear), Mayhem 20x9 8103 wheels ( 0 offset), Amp 35x12.5 Terrain Gripper A/T tires, Express roll up tonneau cover, AVS smoke colored bug deflector, AVS smoke colored in channel window vent visors, 12x18 rear mud flaps, front mud flaps, front door window tint 20%, windshield brow tint 5%.
Absolutely love it! Looks like a truck now. The ride is surprisingly still very nice. With tires and lift the front is 5 1/8” higher than stock, the rear is 3 1/8” higher ( measured on level concrete floor before and after). Even with the lift, I did have to trim some of the plastic and zip tie it back on the lower back of the front fender wells to get the 35’s to not rub when turning. They clear by about 1/8”. With the 0 offset wheels it does provide a slightly wider stance. I didn’t want to go to aggressive. I believe stock wheels are around +17 or +18 offset. The tires are 10 ply but only have 42psi air. Would have liked the rear end to sit higher with the lift, especially when I tow my trailer. I know it may effect the ride, but thinkin about adding in coil rear air bags which will be available in late August for the ‘19. I figured no matter what I do, it will still ride better than my 2010 3500 shortbed did!
Also, adjusted my headlights and we are good to go!
I also did the rough country kit and thought my truck looked to low in the back, I did some investigating with parts department and took a gamble ordering rear springs from a truck with the off-road package and it actually brought the back up a bit over a inch!
Yes, with the lift the rear of mine looks slightly lower than the front but they actually measure the same. The lift is actually approximately a 3 1/2” front and 2” rear to level the truck. Personally, I would rather the rear still be higher. Thinking about some in coil rear air bags when they become available to keep the rear up when towing. I hate a ‘squatty’ truck!Just got my 2019 Longhorn today and this is exactly the look & lift height i am aiming to do myself. Looks Great!. One thing I noticed today was my truck looked uneven from the rear and in your picture of the rear it looks like yours is uneven as well. Anyone else have this issue?
I’m doing a 3.5” lift with 35’s as well. Did you recalibrate for the tires? What’s the MPG’s now?Here it is, all accessorized! 2019 Longhorn (truck details in my signature)
I did not recalibrate for the tire size. On paper after doing the conversion math I was getting right at 16 mpg with approximately 70% rural two lane highway, country roads and 30% in town. The last couple of tankfuls on paper with the colder weather have been right at 15mpg.I’m doing a 3.5” lift with 35’s as well. Did you recalibrate for the tires? What’s the MPG’s now?
Do you know what the overall truck height is withe the 35's and the 3.5in lift?Here it is, all accessorized! 2019 Longhorn (truck details in my signature)
Thank you! The overall height is 80 3/4 inches to the top of the ‘shark fin’ on the top rear of the cab.Do you know what the overall truck height is withe the 35's and the 3.5in lift?
Your truck looks great!
Thanks!!Thank you! The overall height is 80 3/4 inches to the top of the ‘shark fin’ on the top rear of the cab.
The ride isn’t quite as good as stock obviously but still resides very well to me, still as well or better than my stock ‘17 Expedition. On any smooth highway there is not much difference, on a rougher back road it is slightly more ‘bumpy’.Hows the ride though....Im so torn between the 35's and the 295/60R
Good to know thanks... the reason I was asking about the height was because I wanted to see if I can still fit through the brush-less car was in my town....Is your gas mileage horrible with the 12.5's?The ride isn’t quite as good as stock obviously but still resides very well to me, still as well or better than my stock ‘17 Expedition. On any smooth highway there is not much difference, on a rougher back road it is slightly more ‘bumpy’.
