All Fixed Up! Lift, tires, exc.
Good to know thanks... the reason I was asking about the height was because I wanted to see if I can still fit through the brush-less car was in my town....Is your gas mileage horrible with the 12.5's?
During the summer with 70/30 mix of rural highway, county roads (70) and in town (30) I was consistently at 16mpg on paper. Winter it is down to around 15 with the 275/65’s.
Another question for you...how far do your tires stick out from the fender flares? I ordered the Bighorn and it doesn't have them so I'm trying to figure if I should go with the +1 or +14 offset..Thanks
16mpg on the 35's not too bad!
At the top of the flares they stick out just under a half inch. There is a picture showing the side of the truck and how far they stick out at the beginning of this thread. The mpg’s aren’t bad but it is mostly 50-60 mph two lane highway or county roads. That’s about the “sweet” spot for the 3:92 with the 35’s for mileage.(y)
Cool so if I go with the +14 offset without the flares they should stick out similarly right?
With the 12.5’s I would guess it would be close.
Thanks for your help...Much appreciated. I just dont want them to stick out too far so they flinging rocks and really dont want mud flaps, but still wold like a slightly aggressive stance. Ill be mad if they look more stock when all said and done.
Can always get some fender flares to help.
I know thanks but not a big fan of the look....the ones on his truck are much more sleek than the aftermarket ones...maybe if I was running 37's!!!
Gotcha. Everybody has their own tastes. 37s look great with a 6" lift on these trucks tho lol.
My truck just shipped so I'm going to order my tires and wheels this week...If you had 1/8in clearance with the zero offset then I should have about 3/4in with the +14 right?
Yes but remember, I had to trim some plastic and pull the plastic back a bit with zip ties to achieve the 1/8 in gap so without doing this you may be closer than 3/4”
Gotcha....Did you know that Readylift says that your exact set up should work without trimming? I called them out on it the other day. Thanks again
