Limited
I’m refusing delivery at this point. I will see if I can get my deposit back but I doubt it since the dealer says nothing is wrong with it.
Thanks for that chart - I'll throw a temperature probe in mine over the weekend. @Ilovegrits is there any more test data/procedure available?
I did notice an odd blower noise change today just sitting stopped at a light. I do wonder if there is some blend door / recirc door shenanigans going on.
BTW: Whatever you do, don't right-click on that image and say "Search Google for Image..." in Chrome...
Stick a thermometer in its vent and then your F150. Things should get better, not worse.
I am in Houston as well. Today my temp on the patio read 102 degrees in the shade. When my truck eventually gets here I will test the A/C and will refuse the truck if it does not perform well enough.I’m refusing delivery at this point. I will see if I can get my deposit back but I doubt it since the dealer says nothing is wrong with it.
My F150 has been sitting out in the sun and the display say 98 degreees which matches a thermometer I have outside. I started the truck, put on the Max A/C and let it run for exactly 10 minutes. I then took the temp from inside the vent and it stayed right around 45 degrees. Attached is a photo showing the vent temp and ambient air temp on the display. It was freezing in my truck after only 10 minutes on Max A/C and that’s in direct sun and the truck not moving.
Well, I was ready to pull the trigger on a new 2019 Limited.... but each passing day I think it's a good thing I haven't. I live in Fla, so AC is pretty important. I may be waiting for a while.. they have some things to get fixed on this new RAM, or may get a 2019 Denali - since I have only had GM trucks in the past.
I've lived in Florida for 25 years and I'm not the least bit concerned. I should be picking my Limited on Tuesday, assuming it gets from Orlando to Sanford Monday. And, I get from Michigan to Florida tomorrow.
