R
Rob5589
Guest
At this time, unless you want to start the complaint process, there is not much reason to have it tested. You knew exactly how the encounter was going to happen. As soon, if ever, there is a true fix, it will be all over this forum. Until then, use the valve, or deal the the service department smoke and mirrors.Brought my replacement truck to the dealer yesterday for the poor A/C performance... service manager sat in my truck for about 5 mins or so. Had it on low, only the 2 upper driver vents open, fan set to level 4-5, recirc on - if you hold your hand an inch from the vent it feels cool... but never cold. This is after driving for about 30mins on the highway. A/C barely works well enough to take the edge off and make it comfortable. He said it's because it is so humid, but yesterday it wasn't humid at all. Was 28C. The first 2019 RAM I had blew much colder on even warmer/more humid days. His solution was to book it in and do a pressure test and then check coolant level (typical). So... not really wanting to bring it in since that's clearly not the issue with so many people having this problem.
