Yes sir!@Benjams - That cover for the H8 is Mopar P/N: 05033397AE, correct? Looks like it’s ~$12 Online.
Lucky I paid 38 CAD for the part at the dealership. I should have looked around.
If I'm remember correctly, the EcoDiesel will come with AGM battery.So I was just reading through this thread this morning, and recalled that my 20 Big Horn had an AGM battery. Came home from work and, just out of curiosity, looked at the battery in my 22 Laramie, it is not labeled an AGM. I absolutely believed that a two year newer truck would have at least the same type of battery that my last Ram had. Anyone aware of any rhyme or reason to this?
Not for all. My and many others have a H7 regular lead acid from the factory, not AGM.
Regardless, I agree, a H8 AGM will be better.
56029635AC is a Group 94R AGM battery built by Johnson Controls. AGM's are still lead acid batteries, except they are sealed. “absorbed glass mat” AGMI have a 2019 all new 1500 limited with the 5.7 hemi. My battery died and I need to determine if the OEM battery (730 56029635AC) is a lead acid type or AGM type. Nowhere that I can see on the battery does it say what type it is. All the stuff I've read says don't use a convention car charger on an AGM battery. Any thoughts will be appreciated.
May want to consider returning it if you can. You really need an H8I just switched over to the agm as well after the original battery just stopped working with no warning. I went with the H7.
I don't have the 12" screen.May want to consider returning it if you can. You really need an H8
doesn't matter H8 better, IMO.I don't have the 12" screen.
your right.doesn't matter H8 better, IMO.
Doesn't matter what screen you have. The H8 is actually the correct size for this truck. RAM went with the H7 to save money.I don't have the 12" screen.
Not being a **** at all, if you have a 100% stock truck (limited) why do you need a H8?May want to consider returning it if you can. You really need an H8
Tom
You don't NEED an H8. That's just the size. There's plenty of H8 batteries with lower specs than high end H7. All else equal, an extra 6% CCA and 20 mins reserve capacity isn't gonna make a difference and unless you're running on your on battery alone frequentlyNot being a **** at all, if you have a 100% stock truck (limited) why do you need a H8?
Tom
It's not the size of the battery that matters, it's all about how long it stays up. Its all about preference.You don't NEED an H8. That's just the size. There's plenty of H8 batteries with lower specs than high end H7. All else equal, an extra 6% CCA and 20 mins reserve capacity isn't gonna make a difference and unless you're running on your on battery alone frequently
