I believe
@MannyHen has been helping out some people with that as he seems to have a good way to get them via your VIN. Might try sending him a message directly and see if he can help you out.
And as
@Jimmy07 mentioned, we are working back and forth trying to figure out the issue with fobiksafe to save everyone some headache, and he's been an indispensable help in this venture. The actual passive entry side of things works as intended; fob in pocket, grab handle, door unlocks, open door, get in, start the truck and drive away. It's the fobiksafe side that isn't quite right. For those of us that are accustomed to locking the door from the inside as we exit the vehicle, if you do so as you're used to, as soon as the door closes you get the 3 honks as it auto-unlocks. It doesn't matter if both fobs (or however many you have programmed), one fob, or no fobs are in or out of the cab, it still triggers the fobik safe. He believes, and it makes sense, that this is due to a system fault of not having the 5th antenna present (behind the rear license plate). This makes sense as we confirmed an error code present related to it.
So I will second the request to anyone who has had this feature enabled via the sales code addition from FCA and a had a dealership perform the restore process, but you did not add the 5th antenna...if you could please confirm whether or not you get the fobiksafe alert when you shut off the truck, open the door, step out with fob in hand/pocket, press the interior lock button, then close the door, ensuring the fob is outside the cab.
This will be a great help as I'm hoping that we can have this resolved or at least have a definitive answer before I push out a how-to.
