MartyZ
- Feb 29, 2020
Per the owner's manual:
F12 – 25 Amp Clear - Mod Audio Amplifier / Active Noise
Cancellation / SW Inverter
So you'd also lose audio if your truck has an Audio Amplifier. Also, I assume the Inverter is the 110v in the console.
Im going to try this when i leave work and see if it works. I have the tradesman so i dont have the amp for the audio or an inverter. If this is true it should just kill the ANC. Ill post up the results when i get home.
