HarlyFan
The Motorola unit does not have start/stop but it doesnt seem to be needed. I have had no issues since switching from AAWireless to the MA1. I have had it for about 2 weeks and a long road trip and it just seems to work!!!
yea the start/stop is a minor annoyance but only when you are near the vehicle. I miss out on text messages because they both use the same text tone. It's like the boy who cried wolf and I've gotten used to ignoring it until I get an earful from the missesIt's really bad. I spoke to their support and gave them an earful and they're sending me another unit. I was in one of the initial batches so I'm not sure if this will solve anything or not. Will of course keep everyone updated here once I receive it.
In the meantime I'm going to mess with the MA1, but it doesn't have start/stop as said above...so it's not an ideal solution at the moment.
I've been using the MA1 over the past few days and it's flawless. Connects within a few seconds and stays connected the entire time. I had constant random disconnects with aawireless and this thing is rock solid.yea the start/stop is a minor annoyance but only when you are near the vehicle. I miss out on text messages because they both use the same text tone. It's like the boy who cried wolf and I've gotten used to ignoring it until I get an earful from the misses![]()
The start/stop does impact me as my driveway is very close to my house but if Google adds that as native functionality it would be perfect.
It's damn good to know they have acknowledge it's an issue.. That's the most important part.. I can accept technology isn't perfect especially for things like this being new to the market.. As long as the support team/engineers/developers work on a fix then it's a good sign. Guess I'll be downgrading to 1.8OK so I came across a reddit thread where people with uconnect are complaining that this thing is junk after firmware 2.0 or so.
One of the AAWireless employees is pushing people back to firmware 1.8 if you send him a PM. This seems to resolve the issues. I haven't tried it yet.
The thread can be found here:
I was having problems after getting the new app. It would keep reconnecting to the truck after I got out. I enabled start stop and still had problems. I put a widget on my phone screen and would have to tap that to get it to connect. That was my Galaxy S10+. Just got a new S22 Ultra and it works perfectly now. USB mode: MTP with force start. Start start enabled. Passthrough disabled. Takes maybe 20 seconds to connect(phone and AAwireless). No drop outs, works perfect. I did have same issue with old phone when I picked wrong device on start stop. Maybe delete app, reinstall and pick correct device?
This ^ has worked for me. Occasionally takes as long as 45 seconds to connect if the truck hasn't been used in a day. So..start/stop enabled and phone setting changed to keep wifi on all the time. The only issue i have now is that every so often uconnect deletes my bluetooth connection to my phone. I then have to repair my phone and repick device in start/stop in AAwireless. I have read that this is a uconnect /android auto issue not a AAwireless issue.So mine is working most of the time. It takes a little longer to connect but then does. I have start/stop enabled so it doesn't try to stay connected when I get out of the truck. I noticed that sometimes when it doesn't connect it because my wifi on the phone is off. This is a setting on my phone that cuts off wifi if in an unknown area. if AA doesn't connect I cut wifi on and AA connects. I also but a AA Wireless screen widget on my home screen that force restarts AAwireless, occasionally I have to tap that and it connects. I'm going to cut off the turn off wifi feature to see if the helps.
Still working 100% on my Galaxy S22 UltraThis ^ has worked for me. Occasionally takes as long as 45 seconds to connect if the truck hasn't been used in a day. So..start/stop enabled and phone setting changed to keep wifi on all the time. The only issue i have now is that every so often uconnect deletes my bluetooth connection to my phone. I then have to repair my phone and repick device in start/stop in AAwireless. I have read that this is a uconnect /android auto issue not a AAwireless issue.
Hello Snirpo.. I'm sure all of us really appreciate you taking this issue to the forefront. I'm out of town and will be back Monday. I will enable "passthrough" on Monday.. Do you need any logs? <-- I haven't played with how to enable logging so if you have a "how to" link, please shareHi guys,
Chiel from AAWireless here. I found this topic by accident while Googling around for MA1 problems regarding Uconnect.
We are trying to fix these issues properly atm. Firmware 1.8 worked differently logic wise, that's why 1.8 works and 2.x does not. We can of course revert back to the 1.8 logic, but how 2.x works is actually more like the MA1 works. So it's confusing...
@jimbotron 's info is actually quite good. The MA1 does not seem to have these "not starting up after x times" issues, which is surprising.
I was wondering if @jimbotron or @ram!TH@rd can possibly check if the same "no start" issue happens on firmware 1.8 with "passthrough" enabled. I'd expect the same thing to happen as on firmware 2.x. if not, we've found the culprit.
Same here. I am now using passthrough on my 1.8 device. No issues yet (30ish mins driving) - will continually update here.Enabled passthrough on 1.8 on Saturday (wifey drove the truck and set it for me). So far, no eradicate behavior starting AA when truck starts
Thanks for the info. We are getting a bench setup, cause it's impossible to debug this remotely. We have multiple reports of the MA1 working fine, so obviously we are doing something wrong.Same here. I am now using passthrough on my 1.8 device. No issues yet (30ish mins driving) - will continually update here.
Can I have the name of your device? (AAWireless-xxxx or AndroidAuto-AAWxxxx)Gone a full week with no issues
