Most of the time you won't "notice" any knock/detonation unless you're datalogging with some sort of fuel management system in any car, but that doesn't mean it's ok and not having any detrimental effects. If you can actually hear/feel it happening that's probably bad.
As would be expected. I would also expect it to happen dynamicly depending on load, atmospheric conditions, etc., where the ECU is consistently trying to get the best performance out of the engine as conditions and demands change.
This guy did some data logging and it clearly shows timing being pulled with 87.....more so than 89.
Sounds like whoever wrote your tune doesn't know how to tune if you had to run 93 with your 87 tune to prevent st and ltknk retard.I use 87 I feel no difference from 89 or 93, when I had my 04 I did allot of engine work on it can headers, ported heads milled 0.020 that bumped the compression ratio a bit, I had to run 93 and use a tune for 87 to fight timing retard, but there is no knock, the ECU pulls the timing back to prevent it and it was only at part throttle, the truck was a beast with that setup, I see no reason to use high octane with a stock Hemi.
Sent from my SM-G977U using Tapatalk
By the time you actually hear engine knock, damage is already being done to the engine, and you should definitely be worried.I get a bit of knock randomly with 87, but not enough to worry me. I ran 89 and did not notice any difference other than $10 extra a tank.
Because there is definitely a difference with "top tier" gas, and BP isn't the only one who is certified to label that way. It's more than just what detergents are used.On my 2015 Bighorn and now my 2021 Bighorn, I run 87 octane around town and have never had a problem. When I tow I make sure to put in 89 octane.
How come everyone calls it "Top Tier" like we aren't allowed to say that FCA is recommending that we buy our gas at BP Stations? Is that taboo? I buy my gas at reputable stations no matter the marketing claim for their "detergents" in the gas.
It was a caned tune from Superchips, not custom tune, it wasn't available at the time for the 04.Sounds like whoever wrote your tune doesn't know how to tune if you had to run 93 with your 87 tune to prevent st and ltknk retard.
So use which ever one you want ?I'll go with the manual...
Do spends if you use what is recommended, or what will degrade performance, but still workSo use which ever one you want ?
Just remember, it takes more than one tank to adaptives to change and make a difference.I have no trouble with 87 not towing. Don’t need the extra power. Might try 89 one day just to see how much mpg goes up but it probably won’t be enough mpg gains to make it worth it.
Are we sure about this? Seems the sensors would be monitoring this in real time.Just remember, it takes more than one tank to adaptives to change and make a difference.
